CLICK HERE--><--CLICK HERE
BF109E build
Started by Ian Busch, October 11, 2026, 07:20:49 PM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Ian Busch
Hi all , this is the start of my BF109E, hoping to have retracts, flaps and possibly a bomb or fuel tank drop. I have used Walter Musciano's 33" plan as a basis, scaled up to 40" and powered by an OS Max H 40 RC. I have started on one of the most difficult parts, the tail group which has the tail plane supported by the fin with all internal controls and fabric covering on the control surfaces, as opposed to WAM's solid sufaces and external controls. The tail plane is approx 10% larger than scale to ensure positive control. My next part of the build will be the wing with retracts, which I'm hoping to use the Centrak system by Norm Bracken and previously marketed by Bill Johnson. The Centrak unit was featured in the Feb 1967 American Modeler magazine. I have previously mentioned this system in an earlier post, as I have tried to make my own unit, but was unhappy with the operation mainly because the connection points on the unit were not refined enough. I believe Keith Storey has an original unit and installation instruction sheet, but was unsure how to upload photos of the unit.  I was hoping to see some detailed shots of the unit especially the connection points, and the instruction sheet would also be handy. If anyone could assist Keith that would be most appreciated, thanks Ian (Geelong Australia)
Ian Busch
Here is a shot of the tail group together
Ian Busch
Apologies, in my previous post I mentioned Kieth Storey which should have read Keith Trostle
Ian Busch
Here is a shot of the bottom of my Centrak unit rather crudely held together by bolts.
Ian Busch
A shot of the top of the Centrak unit with Roberts bellcrank attached
I have never heard of the Centrak unit.
Is this a retract gear system that works off of line pull?
The J Roberts 3-line system has worked well enough for me over several decades.
Ian Busch
Paul the Centrak works using centrifugal force of the model as it reaches full speed. The Roberts bellcrank attached to the unit operates as per usual, controlling elevators, engine throttle and any other functions required. The Centrak unit was featured in Feb 67 American Modeler magazine and was use successfully by Malvin Meador in his scale Spitfire, winning the 71 Nats.
Ian Busch
Here is the complete article about the Centrak unit.
Pete Bauer
Very interesting with the Centrak unit - I have not seen that before.  Keep posting pictures as the build progresses.
And YES, I agree that you typically need to enlarge the tail plane (larger than scale) to ensure positive control for many WW2 fighters - especially the German ones for some reason.
The mechanical retract setup based on line pull and thus airspeed could actually work.
But with the advent of high-strength Magnaquenc magnets, Intel micro coumputer, and cheap 2.4 wireless radio gear, there are cheaper and better ways to do options in 2026 vs 1967.  Also, I thinking of putting film photography aside.  It's getting hard to find the developing chemicials locally.
Fred C
E-flite makes a set of electric retracts designed for the Bf-109 and Spitfire which requires 81 degrees of rotation. 85 and 90 degrees of rotation will put the gear in the down position at the wrong angle.
I would suggest making the model larger than 33", smaller models are not very tolerant of heavy items such as retracts, the larger the model the higher the wing loading can be.
I would agree the Bf-109 has a rather small horizontal tail, which is typical of fighters. Dive bombers have larger tails compared to fighters.
