  • July 27, 2025, 02:24:49 PM
Author Topic: Bill Mandakis and his P-51 Mustang  (Read 5570 times)
Offline john ohnimus
« on: November 02, 2015, 06:21:55 AM »
Had a blast at Hobby Park in Winston-Salem NC this weekend watching Mr. Bill Mandakis fly his P-51 Mustang fun scale. 6' wingspan, throttle, retracts, moveable flaps, ailerons and rudder. Very nice Bill!!!
Hard Tellin'....  Not Knowin'
AMA 413710
Re: Bill Mandakis and his P-51 Mustang
« Reply #1 on: November 02, 2015, 06:26:14 AM »
Pic #2
AMA 413710
Offline MarcusCordeiro
« Reply #2 on: November 02, 2015, 07:07:09 AM »
Nice!!!
Marcus
Live to fly, fly to live
Aces High!
Here comes Marcus, man..."
Offline Larrys4227
« Reply #3 on: November 02, 2015, 07:28:32 AM »
Are there any other pics around of how he set up the bellcrank/leadouts?
I have a 46-size Hangar9 P-51 that I want to convert, and am looking for ideas on how to set the controls and, "maybe" still be a take apart wing.
Thanks, Larry
« Reply #4 on: November 02, 2015, 07:47:35 AM »
Larry,
   I will have to give him a call and find out all of the details. It does have a removable wing, however I arrived after he had installed the wing.
Tony O
AMA 413710
Offline Fred Cronenwett
    • Lafayette Esquadrille
« Reply #5 on: November 02, 2015, 10:34:59 AM »
You can use the typical RC style design, 1 or 2 dowels from the wing that go thru a former in the fuselage and nylon screws near the trailing edge to hold the wing in place.
Looks like he is using 2.4 Ghz for the throttle, retracts and flaps, makes it easy to install and make work. I have multiple models that all use the same transmitter. I made a clip that goes on my belt to hold the transmitter.
This is our club website with information on CL scale
https://lafayetteesquadrillecl.wordpress.com/lafayette-esquadrille-cl/cl-models/scale/
Look at this video I shot of my RV-4 that shows the removable wing
Fred Cronenwett
Fred Cronenwett
AMA CLSCALE7 - CL Scale
Offline Larrys4227
« Reply #6 on: November 02, 2015, 10:40:57 AM »
Thank you Fred!  I'll peruse all that information .... :)
« Reply #7 on: November 02, 2015, 10:57:08 AM »
Great looking P-51 that Bill was flying....!
Brodak Fly-in will have CL scale June 16-18, 2016. Bill would do well at the contest with the flaps and retracts
Fred
Fred Cronenwett
« Reply #8 on: November 02, 2015, 12:14:08 PM »
I believe Bill has taken it to Brodak but was unsuccessful in putting up a flight. And that is correct about the 2.4 Ghz radio system that he is using. I will talk to Bill and get all of the paticulars for the model.
AMA 413710
Offline Larrys4227
« Reply #9 on: November 02, 2015, 12:26:35 PM »
That would be great ... !!!
Offline Larrys4227
« Reply #10 on: November 03, 2015, 04:47:55 AM »
Fred Cronenwett
Fred --- Excellent video .... Thanks!!  Do you have any information/pics on how you did the wingtip for the lines to go through?  I could see it just breifly in the video .... but couldn't get a good look.
« Reply #11 on: November 03, 2015, 07:33:26 AM »
I will take a picture later today of how I do that that
Fred
Fred Cronenwett
Offline Larrys4227
« Reply #12 on: November 04, 2015, 04:44:06 AM »
Fred --- Last night I started scanning through AMA mags ... I remembered an article several issues ago dealing with RC conversions.  Low and behold .... you are the author of the article I was looking for!!  (June 2015)  How exciting!!   ;D ;D
The line guide position (height and horizontal) seems to be the critical aspect ....  not so much bellcrank position.  Nice drawing you did for the mag on finding the initial spot of the guide.
Much more research to do ... but this is an exciting project for me.
Heres the plane ..... pic taken about 8 years ago.  Its been hanging on the wall of my garage for 7 years ....... I'm not really interested in RC anymore.  How great would it be to get this plane flying in a circle for Fun Scale??!!
« Reply #13 on: November 04, 2015, 02:55:57 PM »
Pull the elevator servo out, drop in a Bellcrank, replace the older receiver with a 2.4 Ghz receiver, add the line guide and you are ready to go. Same airplane, engine everything stays the same as with the RC mode of operation.
You are right the bellcrank location is not that important, the CG and leadout guide location determine the line tension. You can convert this model to CL scale easily
I have been able to make models that have been flown as RC or CL model with a 5 minute conversion
I posted the leadout guide as a separate post in the CL scale section.
Fred
« Last Edit: November 04, 2015, 04:51:07 PM by Fred Cronenwett »
Fred Cronenwett
Offline Larrys4227
« Reply #14 on: November 04, 2015, 07:12:07 PM »
Fred -- Yes, I planned on leaving all the servo's in ... well, I could take the elevator servo out, but its not going to be in the way.  As with any taildragger .... this P-51 has a tendancy to hook on takeoff rollout, but I can't remember which way.  It might need alittle rudder ... I know your article said to have zero rudder offset.
I have a 3" bellcrank on hand .... pretty good one too.  Came out of a Cardinal, I think.  Brass bushed leadout holes and three available positions on the center horn.  Will this do?, or should I get 4" phenolic?
I took the plane off the wall tonight .... motor was alittle tight with gunk and had to free up the carb barrel.  Other than alittle hanger rash .... its in fine shape.
You've got me motivated for this project ....
Thanks again, Larry
« Reply #15 on: November 06, 2015, 04:47:33 AM »
As promised here are the specs for Bill's Mustang;
P-51D Mustang Scale model Specifications
General:
•   The model is a scratch built semi-scale P-51D Mustang built primarily for Fun Scale contest events. It took about 3 years to build.
•   Set-up as described below has very good high speed, low speed, touch-and-go, and stopping on ground while running abilities
•   SOUNDS GREAT TOO.
Size:
•   Wing span = 72”
•   fuselage length = 51”
Engine:
•   Magnum .80 four-stroke
•   Uses 10% Nitro / 20% Castor (as specified in engine specs)
•   8 oz plastic uniflow tank (gets about 7 min on 5 oz)
Operating Surfaces:
•   Throttle control
•   flap control
•   main gears retractable
•   tail wheel retractable (retracts forward – separate from main gears)
Weight:
•   approx. 7 lbs
Radio Equipment:
•   All operating surfaces controlled from 2.4G equipment:
o   Receiver: Spectrum AR600 (6 chan)
o   Transmitter: Spectrum DX5E (5 chan)
o   Battery: 1500 mAh, 4 cell, 4.8 V
Lines:
•   2 lines - 0.021”D X 65 ft
Unique features:
•   Has approx. 2-1/2 in dihedral with lead out wires coming out below the center of the tip to keep the plane level.
•   Constant voltage on glow plug at all times in flight with rechargeable 1.5V battery switching sys.
•   Small amount of rudder controlled via “Mandakis” bell-crank system (i.e. small crank controlled by elevator push-rod); slight right rudder on down control and neutral rudder for up control. This was added just to demonstrate an additional control of an operating surface.
•   The wing is balsa covered with the entire plane covered with silkspan.
•   There is carbon veil on top and bottom of the wing past the main landing gears for additional center wing strength.
•   Of course, because of the size of the plane, the wing is detachable. The leading edge is held by 2 large dowels and the trailing edge is bolted down with 2 metal bolts.
•   The Mustang bottom radiator assembly is a separate attachment by a bolt.
•   Ink-lined as authentic as possible to real Mustang.
•   Finished as the authentic Tuskegee airplanes (i.e. red-tailed).
•   To keep with the Tuskegee theme, the pilot is an African-American flyer WITH a black mustache (as approved by close black flying friend).
•   Parabolic spinner as specified for real plane.
•   With a small amount of effort, the entire cockpit can be removed from the bottom of the fuselage.
•   I say again: SOUNDS GREAT TOO.
« Last Edit: November 06, 2015, 08:54:43 AM by john ohnimus »
AMA 413710
