  • June 25, 2024, 12:01:09 AM
Author Topic: BERKELEY MODELS GRUMMAN AF-2S GUARDIAN (RIB TEMPLATES NEEDED)  (Read 1439 times)
Offline Jim Carter
« on: January 21, 2015, 12:22:26 PM »
Greetings!  I was able to download a copy of the plans for this 53" span model from Outerzone and was very impressed with what I saw.  My problem is the tapered ribs. Would anyone have a set of templates for the ribs for this model?  I could also live with a root and tip template and I believe I could cut a wing from foam.  Any assistance would be appreciated.
Jim Carter
Titusville, FL.
Offline Mike Keville
Re: BERKELEY MODELS GRUMMAN AF-2S GUARDIAN (RIB TEMPLATES NEEDED)
« Reply #1 on: January 21, 2015, 08:42:53 PM »
Could be a bit tricky.  Those ribs tapered not only in width but also in height, being thicker at the root than at the tip.
Offline skyshark58
  • skyshark58
« Reply #2 on: January 21, 2015, 08:54:34 PM »
Would you be interested in buying complete  Berkley kit ?   Mike Potter,  skyshark58@comcast.net
mike potter
