  • August 04, 2025, 03:14:17 AM
Author Topic: scale, semi scale, sport scale  (Read 1622 times)
Offline fernando torres
« on: October 23, 2011, 06:04:20 AM »
What are the differences between the three scale types. I mean, are these AMA  recognized events or categories?  Can semi scale stunt planes( it comes to mind, Al Rabe designs) participate in a scale event? I am not a very good flyer
but enjoy building and flying semi scale stunt models.
FET
Re: scale, semi scale, sport scale
« Reply #1 on: October 23, 2011, 10:26:08 AM »
Read the rules.  "Scale" isn't divided up that way, and "semi scale" isn't a classification.
In scale, you're mostly trying to duplicate the full-size prototype as exactly as possible, and you get a higher static score the better you do.
In Designer Scale (which is the closest to your "scale" that one can come) the judges can get right up to your plane for static judging.
In Sport Scale the judges can't get closer than 15 feet.  Sport scale is intended to be a more relaxed event, obviously.
A semi-scale stunter isn't any official class -- it's just a design approach to stunt competition where a competitor, either because he thinks he'll garner more points, or because of personal preference, chooses to make a model that more or less resembles some full-size prototype.  There's no rule to keep someone from building a Nobler and claiming that it's a semi-scale Cessna 120 -- there's just no advantage, either.
You could, in theory, build a semi-scale stunter and enter it into both stunt and scale competition.  But the two classes have mutually exclusive requirements (the aerodynamic requirements of stunt don't match the outlines of many full size prototypes), not to mention the fact that scale ships tend to be heavier to get more static points.  So you probably wouldn't do well at either, assuming that you could get into the scale competition at all.
The semi-scale stunt plane designer, in order to avoid building a semi-stunt scale plane, must basically build a "stunter in full scale clothing" -- i.e., you've got to choose a prototype plane that sorta-kinda has a general arrangement that is close, then you have to modify the outline into this massive compromise that flies well, but still has people looking at it and seeing the bird that you intend for them to see.  It's nothing like building a scale airplane, where ideally the outline of the full scale airplane dictates the outline of the model.
Offline Jim Fruit
« Reply #2 on: October 23, 2011, 10:41:18 AM »
Fernando:
Of the three categories that you mention, only Sport Scale is an official AMA event. "Scale" (Precision Scale) was dropped years ago because the rules were so restrictive that participation was dropping to only a few master builders.  Sport Scale (judged statically from 15') was adopted to increase participation and it was successful. Your stated "Semi Scale" has never been an AMA event.
Models originally intended for stunt flying instead of scale flying have been flown in scale events. Compared to a specific built scale model, they will probably score less in static judging when comparing the model to the true outline of the original airplane. They could score well in the flying portion because a stunt plane will usually fly better than a scale plane with higher wing loading. Most scale planes today are built with some sort of throttle control to take advantage of the points that can attained by "touch and go, taxi, overshoot, etc." Current rules also require the model is to sit still unassisted, with the engine running, prior to take off. This also requires a throttle.
You best bet is to check the many rules in the AMA website, www.modelaircraft.org. Go to the website / Competition / Rules & regulations. The rules are downloadable or you can just read them there. There are many classes of scale competition too numerous to discuss in detail here. Good luck, have fun.
Jim Fruit
Offline Fred Cronenwett
    • Lafayette Esquadrille
« Reply #3 on: October 23, 2011, 12:04:08 PM »
Tim and JIm have some great comments
One thing to remember is that In CL sport scale 1/2 of your points are the static points (100 static, 100 flying). And a majority of the static points are based on the outlines of the model as compared to the full size 3-view. If you were to enter a CL semi-scale stunter you might get low outline points if the outline of the model did not match the outlines of the 3-view that you present the judge. There are many semi-scale stunt models that look like the full size aircraft but some critical outlines such as top view of the wing have been modified for CL stunt. Another deviation is changing the size of the elevator, same overall shape but it might be enlarged compared to the wing, that is another problem that would cost you points for CL scale static judging.
Another tip - pick the 3-view you show the judge carefully....some are incorrect and some show way too much detail for some events. Choose a detailed 3-view for FAI and a less detailed 3-view for sport and fun scale.
A semi-scale stunt model does fantasticl in Fun scale because you only have 10 static points and 100 flying points, and you can do a stunt option in fun scale but in sport scale they may not let you do inverted laps if the full size version could not do inverted flight.
Tim and Jim are right about the throttle control, to earn maximum flight points you need to have throttle control and use the throttle like the full size pilot would to earn full points for CL sport scale. Pick either 3-line or electronic controls your choice they both work.
Read the rules on the AMA web site regarding fun scale, that would be a great place to start scale with a semi-scale stunter. You also need to create documentation for your aircraft even for fun scale and this should not be taken lightly.
Sport scale requires documentation that matches one particular aircraft and then you have to fly it correctly. Trying to get a model that does well in sport scale and CL stunt would be a tall order.
Good luck,
Fred Cronenwett
Fred Cronenwett
AMA CLSCALE7 - CL Scale
Online afml
« Reply #4 on: October 23, 2011, 12:09:09 PM »
"I am not a very good flyer but enjoy building and flying semi scale stunt models. "
Looks like FUN SCALE would fit the bill nicely..... #^
Please post a few pics of your planes.
"Tight lines!" H^^
Wes
Wes Eakin
Offline John Rist
« Reply #5 on: October 23, 2011, 07:54:33 PM »
If low on experience you may want to consider an electric powered aircraft.  Throttle on electric is easy to setup with an electronic control (Clancy sell a really good setup).  I agree Fun Scale is a good starting point.  The rules even waves the builder of the model rule. So any aircraft including ARF qualifies.  Converted RC are common.
Event 526 is fun scale.
Another suggestion is profile scale - Event 521.  Scale judging is at 15 ft and has 100 points scale 100 points flying.  You can also put a profile scale ship in Fun Scale.
By the way the rules are at:
http://www.modelaircraft.org/files/2011-2012RC-CLScale2.pdf
« Reply #6 on: October 26, 2011, 04:43:40 AM »
Thank you guys.
FET
« Reply #7 on: October 28, 2011, 03:47:59 PM »
There should be a stand "way way off" scale. There would be more modelers involved. My guess.
CB
Offline John Rist
« Reply #8 on: October 28, 2011, 05:45:07 PM »
CB
That is fun scale - and it is growing!
 y1
