  • June 20, 2025, 10:07:59 AM
Author Topic: NA Yale 3-View in Flying Models  (Read 1186 times)
« on: October 13, 2011, 08:23:51 PM »
Does anyone recall which issue of Flying Models had the North American "Yale" three-view?
I've got an RC AT-6 that's in really sorry shape (actually, it'd be in several pieces except for the nyrod outer cladding).  I'm thinking of gluing the wings back together and putting a throttle in it.  Since the plane is without retracts it actually resembles the Yale more than a Harvard -- so I'm thinking of rebuilding it as a Yale.
But I'd have to look through an awful lot of magazines...
Re: NA Yale 3-View in Flying Models
« Reply #1 on: October 14, 2011, 10:12:24 AM »
Finish your Streak.   LL~ LL~ If you do a google on the plane you should be able to find something. H^^
« Reply #2 on: October 14, 2011, 10:56:15 AM »
I'm almost done with the Streak -- it's in the paint shop now.  After that comes an S-1 Ringmaster (well, the S-1 comes after cleaning four plane builds' worth of mess off my bench, but it's the next plane project), and after the S-1 my bench will be open.
The real impetus to  build the thing up is because I fly off of a grass field where "pop-up" takeoffs are mandatory.  So I need a lot of practice on smooth takeoffs for CLPA.  So I was thinking I'd get that plane put back together for 3-line, then when I get a chance to get out to Delta Park and the paved circle, I can just do wall-to-wall takeoffs.  So the main goal isn't to build a scale ship -- but while I'm at it I may as well put a bit of effort into it.
And I've been looking on the web, and I haven't been able to find much on the BT-14.  Lots of AT-6 stuff, but very little BT-14.  Since I know it showed up in FM, which almost certainly means that I have the pertinent issue, it seems a low-cost way to start scheming on what to do to the plane.
Offline Jim Fruit
« Reply #3 on: October 14, 2011, 12:46:24 PM »
Tim:
I took a look through my piles. I have three pages of Paul Matt's three-views for the AT-6, but nothing for the Yale. Sorry.
Jim Fruit
« Reply #4 on: October 14, 2011, 01:22:38 PM »
Thanks Jim.
The BT-14 is perfect for this project, because the model was designed as a SOS AT-6, only without the retracts or wheel fairings.  Since the BT-14 underwent constant evolution to become the AT-6, there are some planes out there that practically are this model.  As long as I can contain my enthusiasm for changing the outline it should be dead simple to refinish this thing to something I can call a BT-14 without too much shame, and get my take-off trainer in the bargain.
Offline Fred Cronenwett
    • Lafayette Esquadrille
« Reply #5 on: October 14, 2011, 07:06:52 PM »
www.bobsairdoc.com
See what Bob Banka has, he has the largest 3-view collection that I have seen, maybe even has some pictures
I looked in my 3-view collection and found nothing but found a small 3-view of the NA-18 in the following book
"North American's T-6" by Dan Hagedorn.
Fred C.
Fred Cronenwett
AMA CLSCALE7 - CL Scale
« Reply #6 on: October 14, 2011, 07:30:28 PM »
He has four or five photopaks, and one three-view.  I'm frustrated because I know I've got that three-view in my possession.
« Reply #7 on: October 15, 2011, 08:40:33 AM »
From what I have read while googling the NA Yale was that the only difference was the Yale had stationary landing gear.   Also looking at the pictures I could hardly see any differences except when the gear was retracted. D>K
« Reply #8 on: October 15, 2011, 10:55:05 AM »
Yup.  Hence, a Texan ARF where the designers left off both the landing gear and the wheel wells is just about perfect.  In this case, changing the nameplate to a different plane is much easier than changing the model to match the nameplate.
