  • July 07, 2025, 11:59:26 PM
Author Topic: any TBF avenger kits for control line scale available  (Read 4353 times)
Offline Butch Hopping
  • if its wrong it has to be right...
« on: January 14, 2015, 07:59:51 PM »
i would like to know if there are any kits or plans available for the TBF avenger,would love to build one for scale.thank you Ron ???
Butch aka Bear,
Offline Fred Cronenwett
    • Lafayette Esquadrille
Re: any TBF avenger kits for control line scale available
« Reply #1 on: January 14, 2015, 08:40:21 PM »
I haven't seen a CL scale kit for that plane but there is probably a RC scale plans or kit that can be converted for CL scale. Due to the lack of dedicated CL scale kits for many years we can been converting RC kits over to CL scale for a long time, it works I fly the great planes RV-4 (56" span kit) with no problems.
Fred
Fred Cronenwett
AMA CLSCALE7 - CL Scale
« Reply #2 on: January 14, 2015, 09:03:54 PM »
Fred thank you i have seen a set of plans for a scale TBF,but it is for rc,I will purchase them plans but i will have a lot of questions to ask as i build it as it will be my first rc kit converted to CL,again thank you,Butch
Butch aka Bear,
Offline Mike Keville
« Reply #3 on: January 14, 2015, 09:16:38 PM »
Many years ago, Consolidated Models, Inc. had a 41" span CL kit of the Avenger.  Although long out of production, you may be able to find plans for that one on the AMA website or elsewhere.
« Reply #4 on: January 14, 2015, 09:36:36 PM »
 If doing it as a profile interests you at all Don Hutchison's C/L profile stunt version is a very scale appearing design that would be an excellent flier. It wouldn't take much at all to make it into a competitive scale model. It's also big enough to present well with out being so large that it's difficult to transport.
« Reply #5 on: January 15, 2015, 01:08:36 AM »
The AMA Plans service lists several Avengers.
One is a 64 inch RC model from Model Akirplane News, Dec 76.  Also a 26" Profile for CL.
Offline Bob Heywood
« Reply #6 on: January 15, 2015, 07:32:43 AM »
Brodak offers the Dare Design TBF rubber / electric FF scale model designed by Mike Midkiff. It is scaled at 3/4in = 1ft, giving it a 41" wingspan. It's an excellent kit. With some mods it might make a pretty decent C/L model.
The Consolidated kit shows up on eBay from time to time but be prepared to spend $$$. It's an old school design but I have seen some built that turned out pretty nice. The plan is available from AMA but is a kit assembly plan and not all the detail parts are shown. The kit's one claim to fame is its carved log fuselage.
Greg, the AMA plan guy can provide reduced or enlarged copies of plans. The TBF /TBM is a big plane. Larger R/C designs can easily be made more suitable for C/L.
Finally, Cleveland Model & Supply Co. offers their Avenger plan in a range of scales. It was originally intended as a rubber model, sort of anyway, but conversion to C/L would not be difficult.
"Clockwise Forever..."
« Reply #7 on: January 15, 2015, 09:39:57 AM »
thank you gentlemen for the replys,i am looking forward to enjoying control line full time now as i have left rc for good,interested in scale and the TBF will be my tribute to the flight 19 Boys,,,
Butch aka Bear,
« Reply #8 on: January 15, 2015, 10:55:55 AM »
This is the scale page we have our club website, I need to add a section with details on how to convert an RC plans or kit over to CL scale
whatever kit or plans you pick make sure to check the outlines with a good 3-view if you plan on entering any contests with it, guys loose a lot of points when wings and parts get stretched from the shape shown on the 3-view
https://lafayetteesquadrillecl.wordpress.com/lafayette-esquadrille-cl/cl-models/scale/
Good luck!
Fred
Fred Cronenwett
« Reply #9 on: January 15, 2015, 11:11:01 AM »
Butch, the hardest part of the conversion will be running the leadouts and mounting the bellcrank.
Just mount the bellcrank as close to the CG as you can while still having a straight run of the leadouts, keeping in mind that a free and low-friction leadout installation is more important than getting the bellcrank nailed down right at the CG.  Then make holes in the ribs (if you want the leadouts in the wing) for the leadouts, put in leadout guides, and proceed.
If that plane has the dihedral angle that I remember, I would be tempted to mount the leadouts externally -- put the LO guide on top of the wing tip, put holes in the fuse for the leadouts, and mount the bellcrank above the wing.  You'll lose some looks (and possibly scale points, if you compete), but you'll gain a lot of ease in assembly.  Then for your second scale CL model you can mount the leadouts in the wing.
You should also find it helpful to study as many magazine plans as you can, to find design elements that you can copy in your conversion.
« Reply #10 on: January 15, 2015, 03:02:23 PM »
Unless you have built a low wing model with dihedral and had an unfavorable experience with the bellcrank/leadouts in the wing, I suggest it is not a good idea not to recommend against doing so.  It has been done on scale airplanes, even semiscale stunt ships with no problem.  Since the possibility that inverted flight will not be flown with the scale airplane, there is little or no problem with the vertical CG and the bellcrank/leadouts can be placed in the wing, in most cases, with little or no problem.
Just saying.  And yes, I know what I am talking about.
« Reply #11 on: January 15, 2015, 03:30:22 PM »
But you don't need to ask how to do it.  I was aiming my post at Butch, who apparently cannot just look at a set of plans and say "ahh, that's how to do it!"
Me, I'd go ahead and whack holes in the inboard wing ribs as appropriate and put the leadouts and bellcrank inside.
Offline chuck snyder
« Reply #12 on: January 15, 2015, 04:50:49 PM »
Skyshark may still have it's TBF kit available. I have this kit in my "to do" pile. In my opinion it is a good sized model for conversion to C/L. I converted Skyshark's Val, and it is the best flying C/L scale model I have.
Chuck
« Reply #13 on: January 15, 2015, 05:22:19 PM »
So, which is it?  You first recommended putting the bellcrank/leadouts above the wing, now you say you would put them inside the wing (which world just fine).  I would also recommend putting plenty of tip weight in the outboard wing which I think is a good idea for any CL scale model.
« Reply #14 on: January 15, 2015, 05:40:05 PM »
Keith, what do you recommend that an absolute beginner to control line fly?  A 150mph combat wing?  A 200mph speed ship?  Or maybe a trainer?  If you say "why, a trainer, of course", then either you only fly trainers, or you think that a recommendation should be aimed at the abilities of the person being recommended to.
I recommend to Butch, to whom it is not obvious how to convert an RC ship to control line, that he run the lines above the wing, because it is easy.  If Butch had been designing and building model airplanes for at least 40 years, and I would tell him to put the leadouts in the wing, because it is pretty.
Butch -- do keep in mind that I'm just making suggestions here.  If, after thinking about things, you're comfortable with putting the leadouts in the wing and you can see how it's done -- go for it.
« Reply #15 on: January 15, 2015, 06:24:06 PM »
Tim,
I was not recommending any kind of airplane.  Butch has already told us he wants to build a scale Avenger.  And he has told us he has built model airplanes before.  So I think it is safe to assume that he knows enough that a scale airplane is certainly not a combat ship or a speed ship or whatever.  Yes, you explained that it would he would "gain a lot of ease in assembly".  In my opinion, there is not much to be gained in the easiness.  You still have to have leadouts, then, you have a leadout guide (in this case on top of the wing) and that does not help make it any easier to finish and paint.  As far as performance is concerned, there is no advantage to have external leadouts and an unsightly leadout guide on top of the wing.  And you do not need to have "40 years of experience" to mount a bellcraank in a wing.
I was just suggesting that there was no technical reason to do what you recommended. Besides, I think it is a matter of opinion if it is easier to have external leadouts with a tip guide than putting everything in the wing.  For me, it is easier to paint the thing with the controls buried than if you have to work around the leadouts and a tip guide, or even if you have a removable guide and detachable leadouts (which is some cases is necessary, like for highly swept wings and such), but that is a whole other subject, beyond the scope of this discussion.  Just as beginner's airplanes and combat ships and speed shps are beyond the scope of this discussion.
Suggest you lighten up just a bit.
« Last Edit: January 15, 2015, 10:17:04 PM by Trostle »
« Reply #16 on: January 16, 2015, 09:34:25 AM »
I thank you for the replies,i only asked because i have never converted a rc ship to control line,i have always built my cl kits from kits intended for cl.i am a decent builder but i have never built an rc aircraft for control line.I do thank you all for the input and was not trying to spark an argument,I  started out back in 1979 building and flying cl and went to rc about 1982,and this past year i had a brain syst removed and a upper spinal fusion so i am no longer able to lug my giants around anymore,so i thought i would come back to cl thats what sparked my love of flying to begin with,i am interested in scale,having built and competed in rc scale,i just love the challenge of scale competition,so i do again thank you all for your input,i will post many more questions in the future,Butch
Butch aka Bear,
Offline Douglas Ames
« Reply #17 on: January 17, 2015, 09:39:53 PM »
I was thinking the same thing. Detailed out, it would make a nice Profile Scale.
AMA 656546
Offline skyshark58
  • skyshark58
« Reply #18 on: January 21, 2015, 12:32:17 AM »
I have a scale Consolidated TBF Avenger kit if you are interested $150.00 + shipping. Mike Potter skyshark58@comcast.net
mike potter
