  • July 13, 2025, 10:20:16 PM
Author Topic: Ansaldo SVA-5  (Read 6006 times)
Offline Clancy Arnold
Ansaldo SVA-5
« on: October 27, 2006, 05:20:47 PM »
Just finished a 1/2 A scale model of the Ansaldo SVA-5.
Hope the pictures come out.  The most unusual feature is the fuselage having a rectangle Cross section back to the rear of the engine and then a triangle cross section from behind the cockpit to the tail.  In the third photo note the cockpit floor is a triangle.
Clancy
Clancy Arnold
U/Tronics Control
Re: Ansaldo SVA-5
« Reply #1 on: October 27, 2006, 08:20:20 PM »
That sounds good, goes with my name.
Clancy
Clancy Arnold
U/Tronics Control
Offline Leroy Heikes
Re: Ansaldo SVA-5
« Reply #2 on: October 27, 2006, 08:24:19 PM »
Clancy;
    A very nice looking model. 1/2a is a nice size to turn out a bunch of models. Please let us know how it flies. I have a 1/2a Sopwith Camel on the way. I have crashed my 1/2a DR1 which was from a Black Hawk kit. The engine quit while I was inverted trying to do a lazy eight. I broke the top wing off and all of the struts.  n1 n1 n1
Leroy
Re: Ansaldo SVA-5
« Reply #3 on: October 28, 2006, 05:19:43 AM »
Thanks Leroy
I hope to test fly it Tuesday.  Will post results.
The model is 18 1/4 in. top wing, 15 in. bottom wing.  Overall length is 17 in. and weighs 5 3/4 oz.  the three circles under the top wing are lead washers of 1/12 oz. each.  Forgot to put them inside the wing.  It balances about 1/2 in. back on the top wing.  Prop is an APC 6x2 on a hot COX .049.
Clancy
Clancy Arnold
U/Tronics Control
Re: Ansaldo SVA-5
« Reply #4 on: November 08, 2006, 04:31:45 PM »
Leroy
Weather here in Indiana finally improved.  Made a test flight today on the SVA-5.  It was squirrelly.  wanted to hunt in the vertical direction.  The model balances 1/2 inch back on a 3 1/2 cord wing.  Jack Sheeks warned me that I should not put incidence in the lower wing.  I think he is right.   One thing this flights short ending did was knock most of the wing struts loose.  The top wing was cocked about 1/4 inch when compaired to the bottom wing until now.  When I went to reinstall the struts the wings are now in alignment?
Also flew two other new models today.  A Baby Barnstormer re-engined from a COX to a Wen-Mack .049 and a 290 Special with a McCoy 049.  The 290 Special will be used to teach my grandsons how to fly C/L.  They watched Grandpa today, even showed them how dangerous props are!
Clancy
Clancy Arnold
U/Tronics Control
