Speed,Combat,Scale,Racing => Scale Models => Topic started by: Fred Cronenwett on November 27, 2013, 08:14:46 PM
In the process of reviewing and revising the 1/2a scale rules for the St Louis Lafayette Esquadrille CL club I have discovered that there is a good number of 1/2a scale contests that are going to be held in 2014
Check with the club website and AMA contest calendar for the exact dates and call the CD to verify the data before traveling to the contest
Milwaukee, Wi Circle Masters CL club June Brodak Rules http://www.circlemasters.com/
Carmicheals, PA Brodak annual Fly-in June 10-14 Brodak Rules http://brodak.com/
Muncie, In AMA Nationals July 11-13 Brodak Rules
Muncie, In FCM Contest Aug 23 Brodak Rules
Sugar Grove, Ill 19th Annual 1/2a Sorta Scale Sept 14 See flyer with rules attached (.051 Max)
St Louis, Mo Lafayette Esquadrille Sept 20 Local Rules (being revised) Contact Fred Cronenwett (Bob Arata is the CD)
Tucson, Az Cholla Choppers Oct Cholla Choppers rules http://www.ccmaconline.org/
Phoenix, Az Central Arizona CL club Scale Oct Cholla Choppers rules http://www.controllinecentaz.com/
Also if you want to fly fast Jim Roselle is having a postal contest for stand-off scale 1/2a powered models (.049 max), and there is no static judging....
Registration closes in Apri of 2014 so now is the time to build. The model has to resemble a full size aircraft, the markings and color is not scale
Read the rules there are some differences on the engines that area allowed
www.coxengineforum.com/t5898-cef-profilescale-reed-speed-rules#73937
Land Softly,
Fred Cronenwett
Thanks for the mention! The more entries the better.
Jim
For the Tucson meet we're still diddling with the dates....probably October 11-12, although those dates are pending approval by the Parks & Rec. Department. Should have firm dates by the time the VSC rolls around in March.
Some changes now being made to our rules here, mostly concerning earlier start/end times. We may make some other adjustments as time goes by.
Contact me at vsc-guy(at)cox(dot)net for updates. Meanwhile, watch for Fred's report on our 2013 meet, scheduled to appear in his CL Scale column, 'Model Aviation', April 2014 issue.
Got this contest flyer today, they have added a 1/2a Event, but look at the rules they do not allow the .061 engines
Fred
The St Louis Rules have been updated, We used the Brodak rules as a guide
Fred Cronenwett
Fred Cronenwett
Love the rules. Hope to make the St Louis contest next summer.
