  • July 07, 2025, 06:11:11 PM
Author Topic: 1/2 A at Brodaks and the Nats  (Read 3065 times)
Offline bob whitney
« on: April 05, 2015, 08:20:23 PM »
  am i seeing right that both Brodaks and the Nats are open to full body's in 1/2 A??
rad racer
Offline Fred Cronenwett
    • Lafayette Esquadrille
Re: 1/2 A at Brodaks and the Nats
« Reply #1 on: April 05, 2015, 08:35:18 PM »
Yeah the rules are setup to allow for full body fuselages, but they have no scoring advantage so Profiles and full body models can compete in the same class. What I find interesting looking at some of the results from the Nats and Tucson is that the main driver for final score is the static score and the bonus points you can earn with multi-engine. The flying points are not the item that separate the 1st to last place.
The Arizona group has been allowing full body fuselages in 1/2a scale for several years now, nice to see some consistent rules for 1/2a scale.
Fred
Fred Cronenwett
AMA CLSCALE7 - CL Scale
Offline Mike Keville
« Reply #2 on: April 05, 2015, 09:03:04 PM »
. . .The Arizona group has been allowing full body fuselages in 1/2a scale for several years now. . .
Fred
Actually, that's not wholly true.  From 2007 thru 2014 ours was a profile-only multi-engine scale contest, although a couple of years ago we allowed full nacelles.  However . . .
Starting this year, the new contest management will welcome full fuselage designs with no penalty for profiles.  Contact CD Keith Trostle (stunteagle at cox dot net) for full details.
« Reply #3 on: April 06, 2015, 12:57:16 AM »
Thanks for clarifying Mike.  Our 1cc Tucson scale rules are on the Cholla Chopper website at
http://www.ccmaconline.org/halfa-multiengine-profilescale.htm
Offline bob whitney
« Reply #4 on: April 06, 2015, 12:18:34 PM »
  tell that to the top 3 in 1/2 A static score at the nats
« Last Edit: April 07, 2015, 07:50:26 AM by bob whitney »
rad racer
« Reply #5 on: April 07, 2015, 07:18:18 AM »
  tell that to the top 3 in static score at the nats
Remember, we're only talking about 1/2 A here.  agreed, in the rest of the scale world, flight scores are super important - in 1/2 A, get ten laps and that's it.
« Reply #6 on: April 07, 2015, 07:21:03 AM »
Way back in the 70's, when a 1/2A Multi Engine Profile Scale event was thought up, the idea was to have a SIMPLE event.  Profile is simple.  Full body is not simple.  So, you (whoever came up with the full body concept) have made another difficult scale event.  Too bad.  To the originators of the concept, it was never meant to be other than a simple event that let one's imagination run wild.
Since this has been stated above, let's look at it again.  The full bodied 1/2 A scale ship "Has no scoring advantage over the profile ship."  Hence, it is STILL a simple event.
« Reply #7 on: April 07, 2015, 09:44:18 AM »
Ron,
I take exception to several points you have made.
Yes, a profile model can be an easier airplane to build.  But if you try to do things to the profile to make it look better, like enclose the pushrod/elevator horn and leadouts, then things start getting to be a bit more complicated.  (The St Louis Broken Arrow contest at least required exposed control systems in an effort to keep things "simple".)  So from some perspective, there is not necessarily a "simplicity" factor when building a profile.
(Another neat feature of the Broken Arrow contest is that the presentation is limited to one page to show proof of scale.  But, an unintended consequence of this rule is that it may not be so simple to get a "good" proof of scale presentation on one page.)
The Tucson Multi-Engine contest rules have bee changed to no longer require a "profile" model.  Our rules follow, somewhat, those rules used last year at the Nats 1/2A contest where the scoring system is such that a profile model is not at a distinct disadvantage over a "full body" model.  In fact, I understand that it was a profile model that won the 1/2A Scale event at the Nats last year (I could be wrong on that).  The rules are such that a good profile can outscore a not so good built up fuselage entry.
After observing the several models that have been entered in our Tucson 1/2A scale contest for the past several years, one could draw a conclusion that full body models would be no more difficult to build than the profile models that have shown up there.
At our Tucson contest, we still have the two categories.  "Unlimited" is for flight options which can include throttles.  The "Limited" category doe snot allow throttles and no flight options.  This Limited category is an attempt to try to keep things "simple".
One thing we are doing for our Tucson contest this year where the models can be full scale bodies, is to initiate a perpetual "Slab" award to recognize the best "true profile" model that uses nothing more than 1/4" sheet in the construction of the wings, fuselage and nacelles.  Of course, allowances are made for firwalls,. firewall bulkheads and doublers.  This would go to the best "slab" model that is entered in either the Limited or Unlimited category.
