  • June 27, 2025, 02:46:30 AM
Author Topic: Phoenix Vintage Race March 28  (Read 17461 times)
Jim Roselle
« on: January 13, 2015, 09:16:51 PM »
Central Arizona Control Line Club is having it's next vintage race March 28th at Esteban Park.
Rules are posted below:
Offline bob whitney
Re: Phoenix Vintage Race March 28
« Reply #1 on: January 14, 2015, 04:08:03 PM »
would like to add the PDQ Circus King
rad racer
Offline darrell albert
« Reply #2 on: July 18, 2015, 08:26:51 PM »
are her any suls to this race?
thanks
darrell
« Reply #3 on: July 18, 2015, 09:24:22 PM »
What does a racing clown look like?
« Reply #4 on: July 28, 2015, 12:38:20 AM »
sorry or miss spelled word.  hat I wanted to know is what were the results were.  number of racers, and times.
thanks
darrell
Jim Roselle
« Reply #5 on: July 28, 2015, 05:15:46 AM »
Looks like a flying clown with 1" thick wing and 301 square inches.
Jim Roselle
« Reply #6 on: July 28, 2015, 05:16:39 AM »
thanks
darrell
Sadly no results to report as participation was extremely low.
« Reply #7 on: July 28, 2015, 08:26:42 AM »
Looks like the SuperTiger C35 with baffled piston is a legal engine. Do the .25's have to run the 9-6?
There seems to be a big disparity in planes with Busters against racing clowns.
« Reply #8 on: July 28, 2015, 09:41:26 AM »
Very true. A Super Tigre Stunt 35 or a Johnson Stunt Supreme would rise to the top of the field, if you still have healthy one.
9/6 or a 25 or 35?  Go with the 35.
Jim Roselle
« Reply #9 on: July 28, 2015, 11:23:57 AM »
All motors run the 9/6. Rules are being modified to specify plain bearing .25s. As far as plane disparity, contestants should choose their model wisely.
Jim
« Reply #10 on: July 28, 2015, 02:57:30 PM »
The difference 300 and 400 square inches of wing comes down to how many flips at the pit stop.
Offline bob whitney
« Reply #11 on: July 28, 2015, 03:32:45 PM »
 looks like the S/T flat top C35 would be legal
rad racer
« Reply #12 on: July 28, 2015, 05:08:29 PM »
Yep, C35 or a JCS or a K&B Greenhead.
I've never heard of a Racing Clown up until today.
« Reply #13 on: July 29, 2015, 10:07:47 AM »
I've seen allot of events come and go over the course of racing for 50 years so take my advise. The event doesn't really make sense. You want sport fliers to bring out what they've got and have fun but anyone with racing experience can cherry pick through those rules and come up with a spoiler set up. Then of course the rules get changed and alienate the serious people OR it becomes a one set up event with a treasure hunt for an engine and all the sport fliers think it's too hard and the whole thing suffers from lack of participation either way. When you have such a tooty fruity blend of equipment you need some kind of equalizer like a speed limit or something.
P.S. Safety thongs and spider wire in racing??
Offline don Burke
« Reply #14 on: July 29, 2015, 10:17:23 AM »
Spider wire OK, safety thongs a very bad idea.  The ability to instantly change hands comes in very handy in tight situations.  Prevents entanglements that would otherwise occur.
don Burke AMA 843
Menifee, CA
« Reply #15 on: July 30, 2015, 09:07:46 AM »
While I have no interest in the event, I am interested in what a CLC Racing Clown is.
Also, every racing event should just pick one specific set on lines and stick to it.  Playing games with line selection has no place in Racing.
If you want to fiddle with lines do it in stunt, scale, or fun flying.
Offline Jim Carter
« Reply #16 on: July 30, 2015, 10:45:05 AM »
Truly, I hope you nor anyone else gets angry with me for this but .... why not??  Why not fiddle with line selection especially if the new materials for the lines have been shown to be safe and acceptable??  We fiddle with props, prop construction, airfoils, covering, wheels/tires, fuel, engines, plugs, and even the fit of the handles, right???
So why not the lines?? I mean other than the physical materials of construction, what's the difference in whether one uses 014 with single kink point failure/rejection solids versus 015 stranded or 018 stranded with multiple kinks to failure/rejection and what seems like a much greater pull strength versus 60# or 80# Spiderwire with no kinks to failure/rejection and even greater/snapping pull strength.  Again, please don't bet angry but help me understand the logic and differences or at least point me to someone who can, please.
I mean, unless I misread some postings Spiderwire and similar products are acceptable in fast combat where "destruction is the accepted standard of the sport, isn't it? So why not racing where line contact is essentially nil except in Team Race events??  We're in a whole new century with a myriad of changes in products, manufacturing techniques and quality controls over what was the standard bearers in the "last century", many of which today, clearly outshine the capabilities and safety of "what was" thinking and technology.
All I'm seeking is a sound bit of information based on testing, use and actual trial versus "that's the way it was and that's the way it will be .... period"!!
Offline bob whitney
« Reply #17 on: July 30, 2015, 11:01:22 PM »
 Jim, i would like to appoint u to do a test on all the diff types of lines and then get back to us with the results
rad racer
Offline Jim Carter
« Reply #18 on: July 31, 2015, 07:42:20 AM »
  :D Okay!  I accept the challenge .... it sounds like it could be great fun and a huge learning opportunity.  I hope no one minds but I may have to call upon you and some others to help an provide some guidance in developing a sound, intelligent summary of the results.
