  • June 26, 2025, 09:18:11 PM
Author Topic: I need some history of the event that is know as Foxberg.  (Read 3517 times)
Offline frank mccune
« on: June 11, 2014, 05:47:39 PM »
      Hi All:
      I would like to know where the racing event that required a Fox.35 Stunt and a Carl Goldberg plane originated.
     I remember that the Wichita club was running a 1 once racing event that required a Fox .35 Stunt and a CG racer kit.  The only kits that were leagal were  The Shoestring, The Cosmic Wind and the Buster.  These were the larger sized kits with about a 42" wingspan.  The tank could be any tank if it held no more than 1 oz.
 This must have been prior to 1980.
      I was in close contact with a chap named David "Hermit" Jones who sent me the rules and reported that it was a great event that placed an emphasis on pitting a Fox .35 Stunt.   I then proposed it to the local controline club, H.A.M.S where the tank size was increased to be no more than 2 oz. of fuel.  I thought that this was a stupid rule as one had to make at least one pit stop in a 70 lap race with a 2 oz. tank  Has anybody ever raced a Fox .35 Stunt that could do 70 laps on an once of fuel? Lol
      Who remembers the time of when the Witchita 1 oz. event was started.  The only other names that I can remember who flew at Witchita at that time was Marvin Denny and Paul Smith.
     Any old timers remember the origin of what is now referred as to Foxberg Racing
        Tia,
        Frank
Offline BillLee
Re: I need some history of the event that is know as Foxberg.
« Reply #1 on: June 11, 2014, 06:45:23 PM »
Take a look at the NCLRA website for the Wichita and Dallas flavors of Foxberg. http://www.NCLRA.org
Bill Lee
AMA 20018
« Reply #2 on: June 11, 2014, 08:45:40 PM »
I'm Paul Smith & I know both Dave Jones & Marvin Denny.  We didn't have Foxberg in Wichita in the 1973-1977 era.
They currently have a Foxberg event at The Brodak Fly In in Pennsylvania.  In 2005 they were using Shoestrings, Busters and Cosmics with Fox 35 Stunts.  The event was spiraling into nothing because only a few people were able to get decent consistant performance with the modern low grade Fox 35's.  The engines were opened up to include the lower-price/higher quality LA25 and Mr. Brodak's new 25.  The event is alive and well as of yesterday.
The airplane menu now includes the Flite Streak and Lightning Streak.  I'm not running the thing, but I would also include other big sport planes such as the Ringmaster and Sig Skyray.  Back in the day, when Carl Goldberg kits were $3.95 and Fox 35 Stunts were $16.95, Foxberg was a good economy event.  The organizers need to look at the economy of today.  Goldberg designs, as well as the Flite Steak & Ringmaster call for specialty machined-balsa parts that most people can't get.
Altough I knuckle-under and comply with the rules, a certain fuel tank coupled with minimum pits stops is a redundancy.
Likewise, a suction tank, outboard tank, and stock venturi size really hits the same issue with three hammers when only one is needed. In the absence of a pressure system, you can't open up the air intake very much and still get off the ground.  Drills and grinders are not controlled substances.  Anybody can hog out a venturi and see what happens.
« Reply #3 on: June 11, 2014, 10:45:31 PM »
The tank is a Sullivan SS2. The reason was a beginner could go into a hobby shop and buy a Fox 35, a Sullivan tank and a CG kit and have something that's easy to get going. It wasn't until I started flying sport stunt that I realized how much work it was to make all this custom racing stuff.
I'm not sure but I think it started in CA at a contest where you had to use the same plane for 3 different events racing, stunt and balloon bust?
« Reply #4 on: June 12, 2014, 07:02:11 AM »
     Hi MM:
      If you think that a beginner could go to the local hobby shop and purchase a Sullivan SS 2 tank and assemble it to be competitive, then you have never dealt with a beginner!
     I learned to loath the SS 2 as it was a bear to get working correctly.  I could purchase a metal tank and convert it to  uniflow in a very short period of time  Or I could leave it as a suction tank with no problems.
    Oh yes, the myth about being able to walk into a LHS and finding a Sullivan SS 2 was just that! it was more rules BS!  The SS 2 made a simple event even more difficult! Paul called it redundant! What difference does the the tank capacity have when there are mandatory pit stops? Most all of CL people had tanks that would would work well in  a Foxberg race.  I think that the requirement to have only a Sullivan  SS 2 tank helped to end the Foxberg event!
        Frank
« Reply #5 on: June 12, 2014, 11:05:38 AM »
There is also the perception that someone with a home made or modified tank would have an advantage so, it's a spec tank to equalize the equipment factor. If your tank is bigger than you need it makes for some interesting strategy. I agree the fuel tank should be open it's a pain but you only have to do the plumbing once. http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXFU47&P=7
Our club has a sat morning beginner program where we teach a class room of kids how to build and fly control line and I also have an intro pilot AMA license so I can teach non-members how to fly. I have dealt with beginners.
« Reply #6 on: June 12, 2014, 06:20:29 PM »
It was known as Shoestring Racing at the time in Wichita.   They had one page set of rules that were very  strict.  They would allow a contestant to use a Ringmaster for one race.   Also the entrant flew his own plane.  With the demise of the Fox 1 ounce tank, the 1 ounce fuel system was then instated.  It was the people that decided that since the Shoestring kit was no longer kitted that the slow rat rules would be used.  Then the people that did not want to learn how to start a hot Fox .35 Stunt brought in the .25 size engines.   Foxberg came about as the other Goldberg kits were being used by some.   How can a person call it Foxberg if other engines are allowed.   Maybe the event should be dropped in favor of the new Slow Rat Racing.   Also what killed the Wichita event was allowing the entrant to decide if they wanted to pit or pilot.
Offline Bob Heywood
« Reply #7 on: June 12, 2014, 07:53:44 PM »
...They currently have a Foxberg event at The Brodak Fly In in Pennsylvania.  In 2005 they were using Shoestrings, Busters and Cosmics with Fox 35 Stunts.  The event was spiraling into nothing because only a few people were able to get decent consistant performance with the modern low grade Fox 35's.  The engines were opened up to include the lower-price/higher quality LA25 and Mr. Brodak's new 25.  The event is alive and well as of yesterday.
Paul makes a good point but I would like to expand on it a bit. In Dayton we arrived at a situation where we got as much out of the regulation stock Fox 35 as could be had. Our races were won and lost by the margin of a single flip or by the time difference of in-laps or out-laps for a pit stop. There was no in-flight passing. Something had to give.
Also, Fox production is now very questionable and sporadic. It doesn't make sense to base an event on an engine that can only be sourced on the secondary market (eBay). Engines must be available from regular retail businesses.
As for the name. Foxberg works for me. Even with the evolution of the class, the fundamental purpose that led to the birth of Foxberg hasn't changed. From my perspective the folks that raced this year at Brodak showed that to be the case.
"Clockwise Forever..."
Offline don Burke
« Reply #8 on: June 12, 2014, 10:31:36 PM »
The reason we here in SOCAL went to 25's was the almost uncontrollable vibration of the FOX 35.  Allows us to build lighter airplanes, plus we're down to 1-1/4 oz tanks to keep the laps under 50.
I never did believe the credo that "Vibration is POWER!!!"
don Burke AMA 843
Menifee, CA
Offline Balsa Butcher
  • High Desert Flier
« Reply #9 on: June 12, 2014, 11:01:58 PM »
Just as a historical note: In NorCal WAM (Western Associated Modelers) raced Goldberg racers with K&B 4011 engines. It was called WAM Sport Race. Single gear was allowed. I don't remember any other details except it was pretty good racing. Engines held up well except for the rings. Vanished along with WAM in the early 90's.  8)
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #10 on: June 13, 2014, 09:43:43 AM »
I've never heard that one but it made me LOL! Fox 35 sure has power!
Online bob whitney
« Reply #11 on: June 19, 2014, 09:01:51 AM »
I Hate fox's even ones with a cromed crank pin  (inside joke) but i went with the flow. i feel the first mistake is when NCLRA went from the Goldberg  kits to any kits ,a few short kits showed up  (plans and a set of 1in thick ribs) then someome found a set of plans for an ugly old profile carrier kit and then that was that so it was opened up to any 300 sq in profile with at least a 1 in thick wing. the clunk tank is no harder to get to work than any other tank but is too big, .at least u can see how much fuel u are putting in it to short tank it ,i agree with a one pit 70 lap race who needs a tank restriction
 i feel that the class just ran it's course as did mouse 2 when a lot of the top flyers all retired at the same time
if we combined the slow rat flyers with the foxberg flyers we would have a good class Bob Whitney, Rad Racer
rad racer
« Reply #12 on: June 19, 2014, 09:42:24 AM »
Canadian Rules LA25 racing is alive and well.  We've had 5 and 10 mile races in Toronto, Detroit, and Dresden for the last six years.  The season finale' is the 100-miler in Toronto.  Surprisingly, the overall completion rate is over 80%.
It's just the basic 300 square inches by 1" wing and an OS LA25.  Less rules than Outback Steakhouse.
The Google Earth is Brad's venue in Dresden.
Do you watch Game of Thrones?  Steve is The Mountain.
« Last Edit: June 21, 2014, 05:19:38 PM by Paul Smith »
Offline BillLee
« Reply #13 on: June 19, 2014, 07:07:58 PM »
Bob, NCLRA has NEVER HAD ANYTHING TO DO WITH FOXBERG!!!!
NCLRA dreamed up the event that is/was called "Fox Race", It NEVER had a Goldberg kit requirement although in the beginning there was a "kit" requirement, later relaxed to use the 300 sq.in formula we use today. As you know, a "kit" requirement is about as much of a joke as a "stock engine" requirement!
Bill Lee
AMA 20018
« Reply #14 on: June 19, 2014, 07:25:52 PM »
Foxberg was big on the east and west coast at the time. Very surprised they didn't go with the Goldberg planes at the nats.
« Reply #15 on: June 21, 2014, 05:22:45 PM »
Carl Goldberg kits were a hot idea when you could buy them anyplace for $3.95.  They went the way of $5.95 Black Widows and $7.95 TeeDees.
We need to base current events on current products, like the LA 15 & 25.
« Reply #17 on: June 22, 2014, 07:59:52 AM »
I see you weren't at the 1987 Chickopee NATS.   With help from Melvin and myself doing the pitting chores my son managed to place second against the Open flyers in the added racing event.  It was done after official flying was done.  What still strikes me funning is when I told my son to lead the plane as much as he could until I tell him to stop.  He didn't need to as his Goldberg Buster was really moving.  If not for one bad stop he might have been in first.   Well he was first in the Junior age.
« Reply #18 on: June 22, 2014, 08:19:20 AM »
I think I placed 2nd in mouse race at the 87 Chickopee nats and they tried to cheat me out of that by saying I wasn't registered until I showed them the entry receipt.
