  • July 18, 2025, 04:01:32 PM
Author Topic: Super Tigre G15/19 engine information wanted  (Read 5251 times)
Offline frank mccune
« on: January 20, 2015, 04:45:22 PM »
     Hi:
     Did the ST G15/.19 engine have a flat top piston or a baffled piston?
        Tia,
        Frank McCune
Re: Super Tigre G15/19 engine information wanted
« Reply #1 on: January 20, 2015, 06:07:34 PM »
YES  ;D .
The G15 / 19 FI is a 16 x 16 version of the G-15 FI ( with the bypass knocked in with a nuber stamp ' 19 ',
though some have the 19 on the mount edge and retain the ' 15 ' .
They came out about 65 , so theres various cases , though to the R/C square & round 72 odd on case with
the muffler mounts . Theres ALSO a G15/19 CAR , with single BR , front Bush , and 1/4 prop shaft instead of 5m.m.
the other internals are the same .
Theres also a ( rare ? ) G 20 19 , similar to the G 20 23 , with baffled piston ?? maybe ?? .
R/C one , CAR version looks same bar crank nose . G 21 collet and G 20 prop driver fits .
1965 odd sucker .
Id presume  :o a FINNED head on one of these ( G 20 ) was BAFFLED , and plain - flat top . maybe . >:(
« Reply #2 on: January 20, 2015, 06:12:32 PM »
Stamp on the  mount .
cept its a X , unless its got a G 15 exhaust port , in which case its a X case G-15/19 ( yea , theres such a thing -
as a X 15 / 19 anyway ) Real X's have narrow square Ex. Port .
« Reply #3 on: January 21, 2015, 04:39:07 AM »
     Hi:
     From what I can determine, the G 20 .19 and .23 engines had a baffled piston with a single rear bearing. The G 20 .15 had a flat top piston. I have a G 20 .15D that that has a flat piston and several G 20 .23 engines that have baffled pistins.
     The G 15 engines had flat top pistons in the .15 and .19 displacements or did the .19 have a baffled piston?
      Am I correct in thinking this way?
        Tia,
        Frank McCune
« Reply #4 on: January 21, 2015, 09:33:52 AM »
I had six G15's, all flat top pistons.
They didn't perform all that well, unless under-propped so they over-revved.  Then they ran good until the rear bearing self-destructed.  We were never able to find a heavy duty upgrade.
The upgraded bearing were found inside Rossi, Cox and Nelson engines.
Offline bob whitney
« Reply #5 on: January 21, 2015, 10:29:59 AM »
Mat pretty much has it  all correct
rad racer
