Speed,Combat,Scale,Racing => Rat Racing and Team Racing => Topic started by: pat king on January 14, 2017, 09:35:35 AM
I am now selling kits of Bill Bischoff's Polecat Goodyear racer.
Pat
Hi Pat.
what is the wing area and stab. I ask because there is an event in the N.W. called B proto which is aimed at newbies. Uses a LA .25 and wing area of 125sq inches 20% stab area. This might get you a few more orders.
Here are the rules.
http://www.flyinglines.org/rules.bproto.html
The wing area is 142 square inches. The horizontal tail is 27.65 square inches, or 19.47% of the wing. If the tip pieces for the horizontal stabilizer and elevators are replaced with 1/2" wide pieces the horizontal tail is 28.81 square inches, or 20.29% of the wing. The vertical tail is 8.94 square inches, or 6.9% of the wing. With the slight change in the horizontal tail the airplane would meet N.W. B Proto rules.
Thanks, Pat
Thanks Pat.
Can you send me a picture of one and I will include it in an article in the near future.
keny6789@gmail.com
Ken,
Picture sent via email.
The wing has cross grain tips. If the tips are omitted and a 3/4" radius is used at the leading edge the wing has 134.9 square inches. That makes the stock horizontal tail 20.5% of the wing area.
Pat
Sounds good Pat.
What comes in the kit and what are you charging for them. I'll get something put in witting soon
Ken,
The kit contains all the laser cut parts, the stick wood, the partially machined leading edge, Aluminum for the landing gear, M4 screws and nuts for axles, 4-40 button head socket cap screws for gear mounting, 6-32 button head and blind nut for bellcrank mounting, 3/32 music wire for the skid, 1/16 music wire for the elevator joiner, and the nylon tip skid for the leadout guide. The kit does not contain the bellcrank, pushrod, or control horn. The kits sell for $105.00 plus postage from zip 60449.
Thanks, Pat
Thanks Pat.
I'll include your notes in the article.
