  • July 18, 2025, 06:33:16 AM
Author Topic: Sportsmans Goodyear kit  (Read 3407 times)
Offline pat king
    • PDK LLC
« on: January 14, 2017, 09:35:35 AM »
I am now selling kits of Bill Bischoff's Polecat Goodyear racer.
Pat
Pat King
Monee, IL
AMA 168941
Offline Ken Burdick
Re: Sportsmans Goodyear kit
« Reply #1 on: January 14, 2017, 10:21:12 AM »
Hi Pat.
what is the wing area and stab. I ask because there is an event in the N.W. called B proto which is aimed at newbies. Uses a LA .25 and wing area of 125sq inches 20% stab area. This might get you a few more orders.
Here are the rules.
http://www.flyinglines.org/rules.bproto.html
Offline pat king
    • PDK LLC
« Reply #2 on: January 14, 2017, 03:51:57 PM »
The wing area is 142 square inches. The horizontal tail is 27.65 square inches, or 19.47% of the wing. If the tip pieces for the horizontal stabilizer and elevators are replaced with 1/2" wide pieces the horizontal tail is 28.81 square inches, or 20.29% of the wing. The vertical tail is 8.94 square inches, or 6.9% of the wing. With the slight change in the horizontal tail the airplane would meet N.W. B Proto rules.
Thanks,  Pat
Pat King
Monee, IL
AMA 168941
Offline Ken Burdick
« Reply #3 on: January 14, 2017, 07:10:28 PM »
Thanks Pat.
Can you send me a picture of one and I will include it in an article in the near future.
keny6789@gmail.com
Offline pat king
    • PDK LLC
« Reply #4 on: January 14, 2017, 09:14:34 PM »
Ken,
Picture sent via email.
The wing has cross grain tips. If the tips are omitted and a 3/4" radius is used at the leading edge the wing has 134.9 square inches. That makes the stock horizontal tail 20.5% of the wing area.
Pat
Pat King
Monee, IL
AMA 168941
Offline Ken Burdick
« Reply #5 on: January 15, 2017, 04:00:43 PM »
Sounds good Pat.
What comes in the kit and what are you charging for them.  I'll get something put in witting soon
Offline pat king
    • PDK LLC
« Reply #6 on: January 15, 2017, 09:30:01 PM »
Ken,
The kit contains all the laser cut parts, the stick wood, the partially machined leading edge, Aluminum for the landing gear, M4 screws and nuts for axles, 4-40 button head socket cap screws for gear mounting, 6-32 button head  and blind nut for bellcrank mounting, 3/32 music wire for the skid, 1/16 music wire for the elevator joiner, and the nylon tip skid for the leadout guide. The kit does not contain the bellcrank, pushrod, or control horn. The kits sell for $105.00 plus postage from zip 60449.
Thanks,  Pat
Pat King
Monee, IL
AMA 168941
Offline Ken Burdick
« Reply #7 on: January 16, 2017, 09:05:15 AM »
Thanks Pat.
I'll include your notes in the article.
