Speed,Combat,Scale,Racing => Rat Racing and Team Racing => Topic started by: Dave Nyce on October 18, 2020, 03:34:39 PM
Hi. Am getting close to having the Royal Rodent plane put together. It will use a McCoy .35 Red Head engine. What prop would be good for this plane with this engine?
a 9x7 or 8x8 would be worth a try. Remember, the engine is happy with a typical 10x6, so whatever you use should put a similar load on the engine. Be sure to post a picture of your model!
Bill Bischoff
find an old 8/10 Power Prop that should hold the R's down or just put a 9/7 on it and enjoy flying it
OK. Thanks. I ordered some 8x8 props.
I installed the recommended rectangular tank from the plan. But there is nothing on the plan for preventing fuel/oil from entering the fuselage. Is a firewall usually installed between the engine and fuel tank? Or is the metal fuse bottom considered ok for oil to go? I drilled a small hole aft in the fuse bottom to allow oil to drip out.
Does the Royal Rodent need a firewall to prevent fuel/oil from entering fuselage? No firewall shown on plan. This is what I have so far (see photos)
The internal surfaces of the top needs to be fuelproofed. These planes never had a firewall.
Thanks!
Finished the Royal Rodent. Didn't like not having a firewall. So mounted a partial firewall coming from the pan, and a partial firewall going down from the fuselage. When together, they slide past one another, and should reduce the amount of fuel/oil that could get into the aft fuselage.
Let 'er rip...!
