  • June 26, 2025, 07:28:40 PM
Author Topic: Goodyear shutoffs  (Read 3148 times)
Offline Kerry Ewart
Goodyear shutoffs
« on: September 10, 2009, 08:33:11 AM »
does anyone know of a good source for some goodyear type shutoffs or plans for some????.
Is Tim Gillott" still manufacturing parts ??? does he have an email address at all????
"If you cannot beat them!JOIN THEM.
Offline Mark Misegadis
Re: Goodyear shutoffs
« Reply #1 on: September 10, 2009, 09:07:01 AM »
I think this link will get you what you need.
http://stunthanger.com/smf/index.php?topic=4325.0
Mark
Offline Thomas Wilk
    • Tom Wilk's old mag plans on CD
« Reply #2 on: September 10, 2009, 04:51:09 PM »
I'm having trouble adding a photo.  send me an email asking for the fuel shut-off drwaing.
Tom Wilk
tawilk36@cpinternet.com
Offline Les Akre
« Reply #3 on: September 10, 2009, 05:05:12 PM »
Hi Kerry
To the best of my Knowledge, Tim isn't making any Goodyear parts such as shutoffs or bellcranks any more. If you could talk him into it, they would be very expensive. Alot of work went into them. You could try phoning him anyway to make sure. Number is: 831-449-2052. Around 9 A.M. or 10 P.M. Pacific time is best to try.
Otherwise, Brodak shutoffs are available, as are some home made units from Dale Long in California. I don't have dales contact info at hand, but I can add it later.
Cheers, Les
Offline W.D. Roland
« Reply #4 on: September 10, 2009, 07:58:14 PM »
Tom Wilk
That is a nice looking shut off!
We used to make our own very simple and reliable.
I think I can put my hands on one( I think I know where it is at)
Will post a pic if I can find it.
It consist of a bent piece of flat aluminum or steel, a bent piece of music wire and a 4-40 or 6-32 bolt and nut.
David Roland
51336
Offline raglafart
« Reply #5 on: September 16, 2009, 03:40:12 AM »
Hi Kerry,
How are you? Long long time since we last met in Brsibane.
Steve Rothwell is making a nice shut offs and he's in Sydney. Very nice units, he does one for Vintage A models and another for Goodyear and rat racers.
Here is a pic I took of both types.
Cheers John Goodwin
John Goodwin
AUS 21261
Offline don Burke
« Reply #6 on: September 16, 2009, 09:56:04 AM »
Darrel Albert sells the "Dirty Dan Shutoff", very similar to the one pictured by Les.
scar4641@aol.com
don Burke AMA 843
Menifee, CA
« Reply #7 on: September 17, 2009, 12:19:25 AM »
How do these shut offs work? (I understand the down elevator activation)
For the life of me looking at these pics I am assuming that they pinch the fuel line but cant tell where the movement is. A lesson would be great.
Thanks Mark
Offline BillLee
« Reply #8 on: September 17, 2009, 06:10:25 AM »
Thanks Mark
The shut-off is comprised of four major components: a body to hold everything together, a plunger that incorporates a U-shaped wire that actually pinches the fuel line, a spring of some sort that applies the pinching force, and a tripwire.
Each of the shut-offs pictured is in the closed position, and neither show a piece of fuel line where it would go. On both, look for the U-shaped wire that goes across the bottom of the body of the shut-off and, in both pictures, is tight against the body: that is where the fuel line will go.
The plunger has a notch in it where the trip wire rests when the plunger is in the "run" position. The second example above shows the notch. When the plunger is in the "run" position (pressed toward the body), the trip wire drops into the slot and holds the plunger in that position.  When the trip wire is pulled back (down elevator and appropriate linkage) the spring-loaded plunger jumps back up and the fuel line is pinched off.
Hope that helps.
Bill Lee
Bill Lee
AMA 20018
« Reply #9 on: September 22, 2009, 10:49:30 AM »
Thanks Bill, This helps confirm how I thought the action works.
Mark
Offline Kerry Ewart
« Reply #10 on: October 09, 2009, 10:27:51 PM »
Hi Kerry,
Cheers John Goodwin
yes john ,been a while thanks for the info and i will contact him.I need some for a couple of bendix models.
kerry
Online Paul Smith
« Reply #11 on: October 10, 2009, 07:09:36 AM »
Here's one attached to the model with everything in place.
It uses the same basic principles as described above.  However, it's not a metal module.  This shutoff is based on two hardwood blocks firmly glued to the model.  It has survived three 100-mile races.
The little eyelet holds the trigger wire, which goes to either to the control horn or a  wire extension soldered to the pushrod.
