  • June 14, 2025, 01:59:08 PM
Author Topic: So what is a good lap time for a reed valve mouse  (Read 1344 times)
Offline Scott Jenkins
« on: February 21, 2012, 12:12:59 PM »
Someone brought this up in a recent thread.
Do not make anything out of this yet just asking. What is a good lap time and heat time for a reed valve mouse. Just finished a reed valve engine runs good on 30 % go juice with an old F2C looking racer  #^ need to play with props a bit more though.  S?P
Scott
Scott Jenkins
AMA 43122
FAI F2C VOLUME 2 SECTION 4, 4.3.7
m) During the refuelling and the restart of the motor, and until the time when he releases the model aircraft, the mechanic must keep the model aircraft in contact with the ground by at least one point and with the centre line outside the flight circle. During that time the pilot must be crouching or sitting inside the centre circle. He keeps one hand on the ground and his handle and his lines as close to the ground as defined by the F2C panel of judges until the model aircraft starts again.
Offline don Burke
Re: So what is a good lap time for a reed valve mouse
« Reply #1 on: February 21, 2012, 08:24:24 PM »
Here's some race results from last year.
MOUSE I   pilot                   pitman     airplane              heat 1-50 laps   heat 2-50 laps      final-100 laps
   1   Dave Hull           Les Akre     Streaker            02:21.23                                    05:10.73
   2   Ron Duly           Don Burke   MiniBLOB III      24 laps                                   06:24.93
   3   Mike Callas   Jim Holland Callas Spec         03:28.64           03:33.91              07:11.91
   4   Dave Hull           Les Akre      Streaker         02:51.34                                  DNS
don Burke AMA 843
Menifee, CA
Offline Les Akre
« Reply #2 on: February 21, 2012, 11:30:04 PM »
Hi Scott
Between 12 to 13 seconds for 5 laps on Sig 35% fuel. We time in 5 lap increments instead of the normal 10, as it gives a better read on the rich-lean during the tank run. If you want MPH using the old AMA speed chart, then double the watch times).
12-13 seconds for 5 airspeed with reasonable pits will place you anywhere from 1st to 3rd in just about every contest held these days.
Les
« Reply #3 on: February 22, 2012, 06:43:25 AM »
Thanks Les, will let you know after this weekend. Have you started your 1/2A2C yet.
Scott
Scott Jenkins
AMA 43122
Offline Les Akre
« Reply #4 on: February 23, 2012, 12:50:34 AM »
Not yet, I do need a backup airplane though....still have a Uniflow tank to test one of these days.
Les
