  • July 26, 2025, 07:05:38 AM
Author Topic: N C L R A & other Good Year Articals . 2005 .  (Read 12035 times)
« on: June 27, 2016, 05:33:41 AM »
Somebody else probly finds these intresting , hant seen them , or was elswhere erstwhile .
http://www.nclra.org/TorqueRoll/2005-04.pdf
http://www.nclra.org/TorqueRoll/2005-06.pdf
 Some perpetrators will recognize their Authorship , I should think .
uva tecnical wizardry , Ronnie Tribe . wot I av'nt seen b'for . https://control-line-flying.com/team-race/
Found Simultaeneously . via this picture . Looking on google pics and going to  ' find site ' .
GINNY .
Addeded 31/7 or VcV .Some Cunning construction by a master craftsman . http://modelflyingnz.org/phpBB3/viewtopic.php?f=26&t=72
and   build threadand summary on B . http://modelflyingnz.org/phpBB3/viewtopic.php?f=4&t=60
ashcustomworks brings the art and craft of hand made guitars together with carefully selected materials to create the guitar of your dreams
Could do an Entry for the Aus. C/L Flying Guitar Comp , too .
further ; Diesel / slow G/Y http://modelflyingnz.org/phpBB3/viewtopic.php?f=4&t=94
« Last Edit: August 01, 2016, 08:00:08 AM by Matt Spencer »
Re: N C L R A & other Good Year Articals . 2005 .
« Reply #1 on: July 31, 2016, 07:12:22 AM »
anda fewa courrenta plansa :
the dreaded NEMISIS ,
« Last Edit: August 01, 2016, 07:53:15 AM by Matt Spencer »
« Reply #2 on: July 31, 2016, 07:31:00 AM »
Up the Garden Path & Back to where we started .  %^@
http://www.nclra.org/TorqueRoll/2011-02.pdf
various permentations of Good Year . Control Line & other exotic words in Google Pics get variouscombinations of drawings ( and pictures ) followable back ' to source ' ,
likea these Eh .
and otheres for inspiration on PAINT WORK ! ( for the Antipodians  S?P) .( And other Island Races . though pomis NOT a RACE . Unless theyre Scotish , etc )
http://if1airracing.com/IF1Web/index_htm_files/Mar1993pdf.pdf
Im Thinking the ORIGINAL INTENT was , as per Mag. articalas , so people could get out and have a ' Scale Model Aero Race ' , on a sunny afternoon . Or sometimes othertimes .
Without necesarilly getting to Het Up & Intense about it .
Original Plans etc are traceable Via hippocket , R.C. Groups " C/L " section , - under    ' Racing Plans ' etc etc , AND the F1 Mag as above Via Google Pics .
So get a chip off the old block , and whittle it into a wing . A FIRST C/L Aeroplane can be a Trainer ( maybe a 8x4 prop .) then a introduction to carving it up , in the middle , with a 7x8 or suchlike ( Changed from 2nd to 4th Gear )
Its Not necesary or essential to get all teched up , A flat 1/2 Sheet Fuse & 1/4 Sheet ( Hard ) wing with rounded edges wont be much slower , and the Colonials run Speed Limit G/Y anyway . Just Glue it well .
« Last Edit: August 01, 2016, 01:21:19 AM by Matt Spencer »
« Reply #3 on: July 31, 2016, 07:44:11 AM »
GENTLEMEN , Start Your Engines ,  :)
nutha Shoestring , a bit moe mellow . These From warren From up the line , here .
The Busta, er . ER .
BOTH suitable as a FIRST Control Line ER .  :) LL~ LL~ mw~ mw~
Theres a Bonzo too - for those new to the game .
a bit off sandpaper & a buster , & youd have it . If it was called ' Bonza ' it'd be the Std Aussie Plane ! . S?P
nuther coupler well likeder ones .
mentions Deerfly / falcon Spl in Org. Artical with this as being the same Airframe . they often evolved , changed hands and were modded over the years.
hence theres a plethoria of variations built ( Full Size ) from the Cassutt & Shoestring Plans , and Updates . So no ones stuck for variety , or choice .
an example . falcon Spl. ( at that stage ) Two Canopies somewhat dissimiler , Along with the paint .
Pommy Falcon Spl / deerfly build thread - https://controllineblog.wordpress.com/2016/02/11/models-british-goodyear/
Plan Mentioed in disertion .
( innocent whistling ' I Know Nuthing ' Icon )
We'll leave it to the experts for the exotica and hardwear . Though the KIWI Open 3.5 cc on 60' wires has some merit , if a .40 open rats to deep a pool . so they say . :-X
( thatll either start a war , or provoke someone to post a real open G/Y race  ;))
« Last Edit: August 01, 2016, 08:35:14 AM by Matt Spencer »
« Reply #4 on: August 01, 2016, 04:23:09 AM »
How to Cheat at GOODYEAR . ;)
« Reply #5 on: August 01, 2016, 04:45:10 AM »
Bolt in an OS 25 . ;D
Brother had his 3rd recent  flight after 40 years layoff , from a hand launch , yesterday .
Muffler on it , 7 x 8 Tornado , roughly Diesel ( 85 mph ) slow pace , straight off . 10% Nitro stunt fuel .
OS 20 & 25 fit eta holes , as does the FSR , FP 20 / 25 etc .
A 20-23 will nail in the G-15 holes .
Likely notta bad idea for getting a few practise hours in , without tearing up your race motor .
And Proves a novice mug can hangf on without dramas , solo at least . Dual Elevators ,
rather than the single ' trim tab ' many use , Better for kicking the speed off for quicker
deceleration at stops , too .
YES , still a way to go with the finish , blue stripes or Red , looks like I have to fork out for some blue paint .  :(
Rustoleum White undercoat & undercoat / paint on it , will wash'n rub back , epoxie a few knicks & dings ,
then break out the masking tape . Fuel Tanks dubious , a cut out's ' on order .
Looks like I'll throw in a ' wobbly leg ' monowheel box , U.C. should be part of the build anayisis , but prevaricated & pressed on .
%^#*! thing flys at least , and Not To Bad . Two Others underway . Fuse Reinforcers and U.C. for them under consideration .
Thinking just glassing the Ginny Fuse should be enough , The flash open shoestring might get a carbon yacht sail batten down
the thrust line . Or Maybe I should do another with it , so Ive Got TWO Shoestrings , the rest to do & theyll be finished .  :P
Sig Kits for beginers , its best just about stock , with a cut off maybe and epoxy impregnated tissue . 10 hour or less , Build Time , that way - your not forever pontificateing over meticulous details of hi fangled etceras . :(
Did it a few coats of dope on wood , H' Wt tissue , maybe stuck on with thinners Then / Or Warmed Aryldite scrubbed in , and spread with a plastic card ? spreader . Paper kitchen Towels used to sponge excess ( Wot Excess )
Needs another thin coat really . Original 76 Ginny was Aryldite / Tissue , Elasticity let it flex without cracking up , and kept the insides inside .
21M is off geting a bit of carving done , should be good to go , in the Cotes Shoestring soon . 25 FSR for a hack / practise engine . Nest thingll be Glass or C.F. props . >:( ' Slow Goodyear at least KEEPS THE COSTS DOWN .
OOps , a picture :
« Reply #6 on: August 01, 2016, 07:34:44 AM »
Here He Goes , Again ,  %^@ Tripping over related contrivances .  >:( pinching the picture from : http://www.airrace.com/1949%20NAR%20.htm
going to ' borrow ' the lot , on this ,  ;) not sure I consider abduction a service , but abducting the abducted , Liberating It , may well be .  ;D
Someone'll let me know if Glen & Bill are Kin , ? .
« Last Edit: August 22, 2016, 02:43:40 AM by Matt Spencer »
Offline bill bischoff
« Reply #7 on: August 01, 2016, 06:47:21 PM »
No relation between Bill Lee and Glenn Lee. They are both quite good, though  :D
Offline Bob Heywood
« Reply #8 on: August 01, 2016, 07:19:43 PM »
Miss D.A.R.A.
"Clockwise Forever..."
« Reply #9 on: August 21, 2016, 11:49:10 PM »
Much Appreciated , pichers of the Detroit Area racing Association MISS are HARD TO FIND , And ive got RED . AND I found the metalic blue , but its touch up paint for the horseless carrage ,
Just found these , notable photographs , and a artical with some rare race pics , but thohmson Trophy stuff .http://www.enginehistory.org/members/Convention/2015/Presentations/UnlimitedClassAirRacingHx01.pdf
V rare colour stuff there i hadnt seen .
« Reply #10 on: August 21, 2016, 11:55:33 PM »
« Last Edit: August 22, 2016, 12:42:55 AM by Matt Spencer »
« Reply #11 on: August 22, 2016, 01:49:26 AM »
1949 ; the Ginny is in there up to the left . pusher'd be intresting .
« Reply #12 on: November 21, 2016, 03:35:56 AM »
Hows This for ' far out & groovey '
