Speed,Combat,Scale,Racing => Rat Racing and Team Racing => Topic started by: C.T. Schaefer on November 24, 2013, 06:51:38 PM
Title: Lines for racing events
Post by: C.T. Schaefer on November 24, 2013, 06:51:38 PM
One of our fellows asked me a week or so ago if the non metallic lines that are used in combat are legal for any of the C/L racing events. I had no answer so thought I should ask here. Official answers??   Thanks
Title: Re: Lines for racing events
Post by: bill bischoff on November 24, 2013, 08:31:30 PM
They are only legal in competition events where the rules specifically approve their use, so at this time they are not legal in racing.
Post by: C.T. Schaefer on November 25, 2013, 06:23:08 AM
Thanks. I'll pass it along.
Post by: BillLee on November 25, 2013, 01:20:46 PM
Should they be legal for racing events?
As we all know, they are legal for combat competition. And, of course, may be used everywhere outside of actual competition (per the AMA rule book).
Are there any advantages to non-metallic lines for racing?
Post by: john e. holliday on November 25, 2013, 08:45:17 PM
Won't know until someone tries them.   I don't think I would try them in competition, but if I had a fenced in area I would do some experimenting.
Post by: Dave Edwards on November 28, 2013, 01:00:55 PM
FYI - GSUMP lines have the following equivalence and general use in combat:
100lb test = 0.018" Speed limit combat
80lb test = 0.015" F2d combat
60lb test = 0.012" 1/2A combat
Post by: Dave Edwards on November 28, 2013, 01:06:09 PM
Experience in combat has been great - I will not be going back to SS unless required.  Lines last longer and plane flies much better with them.  Esp tru in combat as they fly out of line tangles much much much better than any steel lines.  No curly que lines, no kinks, easy to tie knots (but be sure to tie the right ones!).  Buy lines from cabelas at 1/2 the cost of steel.  Lines are bright yellow so you can see them in the grass.
Not sure they are needed in racing.  Could consider them in clown if we move to 60' as they are much lighter than steel and might help these small planes on long lines.  Needs testing.  Maybe solves a problem that does not exist in the first place.
Post by: Melvin Schuette on December 08, 2013, 08:49:34 PM
Here is the problem I have with the Spectra lines for any competition use.  There is no way to determine what the lines are made of.  There is no way to measure the diameter of the line.  If you try you will crush the line making it smaller.
Melvin
Post by: Dave Edwards on December 10, 2013, 05:35:52 PM
Material identification can be an issue but that is a problem with all lines, not just GSUMP.  Other than speed events, we dont have a line material spec for any events.  Problems may arise when a reliable source or brand changes their formula in some way that affects us.
Measuring line diameter can be done, its not as easy, but it can be done repeatably.  Measure with a light touch.  Crushing the line makes it harder to measure but does not affect the strength of the lines.
An effective pull test provides a backup, just like our existing lines.
In my opinion, the added performance and safety of these lines greatly outweighs these potential issues.
Post by: Paul Smith on December 26, 2013, 06:12:04 PM
I believe that in combat, speed, and racing the lines for each event should be held to an identical standard so as to equalize that factor.
There are many ways to compete and try to excell.  Beating the system with trick lines does not need to be one of them.
Post by: dale gleason on January 02, 2014, 12:39:39 PM
One factor that seems to be overlooked in the use of Spectra lines is their electrical conductivity, or lack thereof. Being non-metallic, wouldn't they have a margin of safety over metallic lines when it comes to high-tension power lines, etc?
dg
Post by: Paul Smith on January 02, 2014, 01:24:06 PM
Electrical conductivity?  Don't bet your life on it.  If the lines get a little wet, you might have your brain sizzled just like with metal lines.
Are you considering holding contest in an Edison easement and using plastic lines.  Good luck.
With metal lines we can specify a certain metallurgy and mike the diameter.  Therefore we have positive knowledge of the strength.
Plastic fish lines are a bowl of jelly.  You can't determine either the diameter or material of a spool of fish line.  Using the the stuff in contests is nothing but trouble.  If the line breaks while you're fishing the fish lives another day and nobody gets sued.
For sport flying, you're on your own.
Post by: Dave Edwards on January 02, 2014, 06:46:49 PM
I wouldn't depend on ANY line material to make flying near power lines safer.
Good point on specifying the material - I haven't seen an industry standard such as ANSI related to these materials so we are relying on our pull tests a bit more.   BUT, data from the combat field shows fewer flyaways with GSUMP than with steel and I would not agree with your assessment on trouble or liability.  Measuring lines is not an issue either.
For combat, I have no doubts about the improved safety with GSUMP due to greatly improved performance during line tangles.  For other events, including racing, the safety improvements are limited to eliminating kinks and curly-cue lines.
Post by: dale gleason on January 03, 2014, 03:06:12 PM
Judging from the references to flying in electrified fields, I didn't pose the question too well. I'll try again:
In looking at the "pros" and "cons" of metallic lines vs GSUMP lines, does the conductivity, or lack thereof, of GSUMP factor into the "pro" side or the "con" side?
dg
Post by: john e. holliday on January 04, 2014, 08:48:27 AM
I was going to say something about flying close to high tension lines.  But, then I remember Billy Melton talking about his flying low at the NATS  in carrier.  He told me that in the summer time in Las Cruses NM he would get static shock if he flew very high in the circle.   At Pawnee Rock KS we were getting static electric shocks one year.   All CL flying stopped that day.  Don't know if the new plastic/composite lines would have helped or not.
Post by: don Burke on January 04, 2014, 09:16:46 AM
Probably not if they were damp or wet.
Post by: Charlie Johnson on January 04, 2014, 10:48:28 AM
Ask Sparky what happened when his combat model and stainless lines got into the high voltage cables during the Nats in Lincoln.  Combat events now require a wrist restraint as well as a shutoff should the lines be cut.
A catastrophic failure in Racing (both lines break) is much more serious than in Combat where (hopefully) the shutoff works properly.  Unless you're an idiot flying near high tension lines the danger isn't to the pilot but to spectators and pit crew or expensive transformers in the case of the Lincoln Airport situation.  The price of a 900 meter spool of 100 pound test line on eBay is about the same price as a single set of stainless flying lines
in a hobby shop or half the price of bulk line.  They can be tied to an exact length, they'll pull test to near 100 pounds even with the simple knot suggested on the Combat Forum.  The lines will eventually fray at the leadout guide but that shouldn't be a problem with racing models since there isn't the movement compared to a constantly maneuvering combat model.  So far there have been no catastrophic failures with combat models.  I'm really more
concerned with a fatigued pilot trying to hold onto a GO 25 powered Slow Rat for 140 laps.
