  • July 18, 2025, 02:34:34 AM
Author Topic: How much pressure?  (Read 2454 times)
Offline frank mccune
How much pressure?
« on: January 20, 2020, 03:36:57 PM »
     Hello All:
     How much pressure is generated by using timed and untimed crankcase pressure when using a pressure fuel system?
     Perhaps the answers shoul be psi.
        Tia,
        Frank McCune
Tom Vieira
Re: How much pressure?
« Reply #1 on: January 20, 2020, 03:42:33 PM »
I recently read an article by Bill Lee from an old magazine.  I believe it was about 1PSI with no check valve. 1.25 with.  Doesn't sound like much, but it's still an increase!  I may be wrong, however....
Sent from my SM-G960U using Tapatalk
Offline BillLee
« Reply #2 on: January 20, 2020, 07:25:50 PM »
That's pretty close, T.J.
What I wrote was
" ... a test stand to measure this and found that the tank
pressure from an untimed crankcase tap is about I.4
psi, or about 1.6 psi if a ball-check is used in the
pressure line."
Yes, this is  crankcase pressure, not timed pressure, but what most folks would use.
ps; this may be found on the NCLRA website at  http://www.nclra.org/TechTopics/UniflowPhysics.pdf
Bill Lee
AMA 20018
Tom Vieira
« Reply #3 on: January 20, 2020, 07:27:37 PM »
Not bad for not going back to look it up!  Hahahaha!
Thanks for the correction!
Offline bob whitney
« Reply #4 on: January 20, 2020, 09:11:51 PM »
I have never liked timed pressure .most times don't use a check valve
rad racer
Offline BillLee
« Reply #5 on: January 22, 2020, 09:26:46 AM »
Timed pressure is allot more, so much it will make your needle valve very sensitive. I use check valves I make myself on un-timed pressure but they need constant flushing out with straight methanol. Any dried oil gets in there you're done.
Motorman 8)
+1
Bill Lee
AMA 20018
Offline Tim Stone
« Reply #6 on: February 04, 2020, 03:13:19 PM »
Motorman 8)
   I have enjoyed your input over the years. Do you consider yourself a current competitor or retired? I have not seen you
at the Nats in my 32 years since re-entering and attending the C/L racing Nats
