  • June 27, 2025, 10:51:30 AM
Author Topic: CLown plans in a CAD format  (Read 1557 times)
Offline Scott Jenkins
« on: May 27, 2009, 11:40:08 AM »
Hi all,
Trying to get ready for the NATs and need to build a new clown for racing.
Does anyone have the plans in a CAD format, *.dwg, *.DXF, or *.igs.
I lost my last set on paper when I moved my shop.
Scott
Scott Jenkins
AMA 43122
FAI F2C VOLUME 2 SECTION 4, 4.3.7
m) During the refuelling and the restart of the motor, and until the time when he releases the model aircraft, the mechanic must keep the model aircraft in contact with the ground by at least one point and with the centre line outside the flight circle. During that time the pilot must be crouching or sitting inside the centre circle. He keeps one hand on the ground and his handle and his lines as close to the ground as defined by the F2C panel of judges until the model aircraft starts again.
Re: CLown plans in a CAD format
« Reply #1 on: May 27, 2009, 12:44:22 PM »
You might email Pat Johnston
« Reply #2 on: May 27, 2009, 02:00:10 PM »
Thanks guys I got them.
Scott
Scott Jenkins
AMA 43122
« Reply #3 on: May 27, 2009, 05:11:10 PM »
As Brodak does the clown kits, why not get the plans from him?  DOC Holliday
