  • July 18, 2025, 06:33:26 AM
Author Topic: Goodyear fuel  (Read 4806 times)
Offline big ron
Goodyear fuel
« on: December 01, 2014, 07:44:40 AM »
What fuel is being used in Dallas Sport Goodyer
John Blanchard
Brusly, Louisiana
 AMA 1054488
Offline bill bischoff
Re: Goodyear fuel
« Reply #1 on: December 01, 2014, 11:52:33 AM »
What we are currently using is Powermaster RO-Jett 10% nitro, 5% castor oil, 17% synthetic oil. We have also used PowerMaster GMA 10% 11/11 oil, Ritch's 10% 10/10 oil and 10% 5/15 oil. All work well, but the ASP's don't really need a lot of castor.
« Last Edit: December 06, 2014, 12:25:43 AM by bill bischoff »
Offline Gary Mondry
Re: Goodyear fuel
« Reply #2 on: December 01, 2014, 09:54:24 PM »
What do you do if some poor schmuck shows up with a Fox?  And now that HobbyPartz is out of stock of the $43 ASP, where's the next best place to get a compliant engine?  Either Tower or Hobby People at $70?
AMA 10663
Re: Goodyear fuel
« Reply #3 on: December 02, 2014, 11:23:15 AM »
People are still running Foxes. I've run mine on all the different fuels and it doesn't complain. If somebody wanted to run 11/11 fuel rather than 5/15 or 5/17, I'd let them, assuming we had some for them to use.
The ASP's will be back in stock. I've seen them run out and re-stock more than once. If you're in a hurry, you could buy a Magnum from Hobby People or Tower. Even at $70 it's a decent deal.
Offline Gary Mondry
Re: Goodyear fuel
« Reply #4 on: December 02, 2014, 06:39:26 PM »
No hurry.  I guess I'll try to wait HobbyPartz out.  I hope you're right, but I'm skeptical.  My Fox is marginal on restarts already.
Thanks for the reply.  Your new Margaret June looks great!
AMA 10663
Offline bob whitney
Re: Goodyear fuel
« Reply #5 on: December 02, 2014, 10:18:11 PM »
will a fox keep up with the ASP
rad racer
Offline BillLee
Re: Goodyear fuel
« Reply #6 on: December 02, 2014, 10:48:22 PM »
In what little experience I have, a good Fox (i.e., one that runs well and restarts hot) will keep up quite well with the ASP/Magnum engines. The venturi size and other constraints levied on the ASP/Magnum models makes them essentially equal. (That was done on purpose.)
That being said, it is a lot easier to make the ASP/Magnum run and restart hot, and VERY difficult to get  a Fox to do the same.
The idea is that if the ASP/Magnum engines prove to be too fast for the Fox to be competitive,, just like TQR, the venturi size can be adjusted.
Bill Lee
AMA 20018
Re: Goodyear fuel
« Reply #7 on: December 03, 2014, 01:44:38 PM »
Yeah, what he said!  H^^
Offline Peter Grabenstein
Re: Goodyear fuel
« Reply #8 on: September 25, 2015, 06:58:42 AM »
Hi all
I am getting ready for my first "La Jollita" Indy Race next week.
http://stunthanger.com/smf/index.php/topic,37494.0.html
Thinking about race fuel mix for my HP.15 Bluehead like 10%Castor oil, 10%Synth.Oil, 70%Meth. + 10%Nitro.
For my understanding:
Engines are running hotter on temps. with Synth. oil .
How would this affect hot restarts in this HP .15 Bluehead case ?.
The engine is run in well on 20% Castor oil + 5% Nitro mix.
Thanx for any hints.
Peter  H^^
I hate pessimists, I prefer optimists.
Impossible is done immediately, miracles take longer.
I don't care who your father is ......... as long as I fly here,
Nobody walks, runs, floats or flies across my circle ......... not even to fetch fish, wine or bread.
Re: Goodyear fuel
« Reply #9 on: September 25, 2015, 03:41:20 PM »
The 10/10/10 mix should work fine. That much castor is not necessary, and you could also run 5% castor/15% synthetic if you prefer. we have used both.
Bill Bischoff
