  • July 18, 2025, 06:18:19 AM
Author Topic: fueling bottle  (Read 10653 times)
Offline Fred Quedenfeld jr
fueling bottle
« on: August 22, 2015, 08:56:19 AM »
what do you use for a refueling bottle?
where do you purchase
how do you modify
thanks
Fred Q
Offline bill bischoff
Re: fueling bottle
« Reply #2 on: August 22, 2015, 03:22:19 PM »
Fred, go back one page in the racing section (here) and read my post "racing fuel bottle". McMaster-Carr, $9.15.
BB
Re: fueling bottle
« Reply #3 on: August 23, 2015, 04:48:15 AM »
There was a Melvin Schutte product on the market a few years ago.  It has a nice brass check valve setup.
Offline qaz049
Re: fueling bottle
« Reply #4 on: August 24, 2015, 05:45:16 AM »
how do you modify
thanks
Fred Q
I mostly use diesels, so I look out for bottles that will match the screw size of the plastic caps for my Kerosene containers. These are roughly about 32 mm in diameter. I know that they will be solvent resistant, are able to be drilled, and will last for quite a time. Next I look for bottles of about 400-500 ml made of a reasonably soft but tough plastic that will fit the caps. I try to choose those with a "4" or a "2" in a triangle symbol on the base. Babies bottles, solvents and those in which Octane or Cetane boost petroleum products or similar are sold meet these criterion. A single cap will outlast a few bottles normally. Alternatively those for ladies hair products often work well with their own or a different cap..
I then make a "male" self sealing spring loaded device based on a Brass 3/8" RCA SCAT audio connector. The ones available locally have a 3/8" UNEF thread and nut. This fitting is machined to take another machined hollow Aluminium shaft with a horizontal hole sealed by a spring and o-ring as shown in the pic below.
The Delrin "tip" is a force fit into the central shaft.
A similar "female" device sits in the fuel tank.
I'd imagine that the same fuel bottle idea would work just fine for glow fuel with a modest Nitro content.
« Last Edit: August 24, 2015, 07:29:36 AM by qaz049 »
Offline qaz049
Re: fueling bottle
« Reply #5 on: August 24, 2015, 06:53:08 AM »
More pics:
Plunger open:
Closed:
Female valve in GF Tank.
Re: fueling bottle
« Reply #6 on: February 19, 2016, 10:18:54 AM »
Just got my fueling bottles from McMaster-Carr.   I like the little cap on them.   One will be for diesel.  After all these years I finally fired up my Rivers I had gotten from Dave Platt many years ago in a trade.
Offline Duke.Johnson
Re: fueling bottle
« Reply #7 on: February 19, 2016, 10:58:51 AM »
BB
Have a link to the thread or Mc Master Carr?
Offline Ken Burdick
Re: fueling bottle
« Reply #8 on: February 19, 2016, 12:56:04 PM »
black squeegee bulb.
Offline Dave Edwards
Re: fueling bottle
« Reply #9 on: February 19, 2016, 05:33:17 PM »
For sport racing events I have switched from a squeeze bottle to a 4oz syringe that I can operate one handed.  Available from MBS.
Re: fueling bottle
« Reply #10 on: February 20, 2016, 10:36:20 AM »
McMaster-Carr Fuel Bottle part #1044K4 at $9.15 each plus shipping.
Offline bob whitney
Re: fueling bottle
« Reply #11 on: February 20, 2016, 12:04:04 PM »
  the one thing i dont like about a self closing spout for glo is that it makes it hard to exhost prime if u need it
rad racer
Re: fueling bottle
« Reply #12 on: February 21, 2016, 02:38:29 PM »
These don't come with a valve.   Just a screw on cap.
Offline KSeaton1
Re: fueling bottle
« Reply #13 on: February 22, 2016, 10:40:06 AM »
Doc why not call me and get what you need. I still make them.  Kevin.
