CLICK HERE--><--CLICK HERE
clown racing
Started by Joey Mathison 9806, August 14, 2006, 03:25:57 PM
Previous topic - Next topic
0 Members and 2 Guests are viewing this topic.
don Burke
Doc,
Unfortunately we can't stop technological progress.  Although I remember how great it was when I was racing FAI-TR 40+ years ago, I can't help but wish we had had the engines available then that we do now.   Although I'm not now able to particpate in F2C, nor want to, due to my age and slow relexes.  F2CN is still enjoyable, except for the stinky fuel, and it sure is easier on the pilot!
So I do that and Clown, SSR, and even BTR things.  I must brag that we Duly/Burke were the first to go 300 laps in Clown at the NATS and the first to do it with an over-the-counter F2D engine.  I also was one of those who planted the seed for the SSR class even though I thought we should have just allowed those engines in the FOX race.
I don't see anything wrong with the engine rules in Clown, but do feel that when someone really does it right with an F2C engine, it will be all over for everyone else.   It's taking a little longer than I thought last year, but I still think it will happen.  So what to do?   I think we should change the Clown rules to stop that.  But most want to wait till after it happens as no one seems to be willing to prevent it in the first place, cest l'guerre.
don Burke AMA 843
Menifee, CA
john e. holliday
What would you change in Clown Racing?  I remember we campaigned for years to get Rat Race down to 21 size engines to no avail.  Even tried that with Slow Rat, same results.  Now we have Hamster Rat and still fewer Slow Rats.  I think the late Ken Smith had the right idea with B-Team Race in limiting the speed limit and the designs.  He was hoping to make it a spectator event when I talked to him, in that it would be slow enough we could have 3 or 4 planes up at a time.  I love racing and carrier, but, have run out of room and no one to practice with.  DOC Holliday
Dave Rolley
The way to stop the F2C engines from becoming THE engine in Clown is to limit the event to non-integral fin engines.  Integral fin liners (the liner and the cooling fins are one piece) and integral fin blind bore engines (the liner, cooling fins, and head is machined as a single part) are a good deal of the technology jump from the older F2C engines.  Of course, ABC and AAC liners, good bearings, and affordable tight tolerance manufacturing processes help.
Doc, the problem with the .21s in Rat was they were almost as fast as the 40s.  For a fun event, the pilot is the primary limitation.  When it gets too much like work (the pull in slo rat) or the model is too fast for the once a month pilot, the pilots drop out.
It is the same problem faced by F2C today, there are way more mechanics than pilots.  And that was true when I first got interested in 1975.  There were 4 F2C mechanics (or mechanic wantabees) in Denver and and one F2C pilot back then.  Unfortunately the pilot and one of the mechanics moved to New Mexico about that time.  I didn't find a local pilot I could work with until my son decided he wanted to fly.  Maybe that statement should be I didn't find a pilot that could work with me until my son started flying.  Either way, I didn't get serious about the event until I had a pilot.
Like I said earlier in this thread, you have to make it work at the local level.  If that means additional controls or rules, then that is what it takes!
Randy Bush
Quote from: Joey Mathison 9806 on August 14, 2006, 03:25:57 PM
what engine is the hot setup for clown racing?
As of yesterday, Vic Garner's latest engine is a "hot setup".  Also, it's on a good plane.  I don't have important details.  It's an engine that I've never seen on a racing circle, and it's not expensive.  Kind of supports the idea that there can be many hot setups in Clown.  That continues to be the special charm of this event.
The downside is that the wide variations in airspeeds among the planes in a heat results in some very challenging piloting.  The upside is it's never dull, and there's always something for the engine tweakers to experiment with.
Cheers,
Scott Jenkins
Randy,
OK, I'll bite which motor is it.
Scott
Scott Jenkins
AMA 43122
FAI F2C VOLUME 2 SECTION 4, 4.3.7
m) During the refuelling and the restart of the motor, and until the time when he releases the model aircraft, the mechanic must keep the model aircraft in contact with the ground by at least one point and with the centre line outside the flight circle. During that time the pilot must be crouching or sitting inside the centre circle. He keeps one hand on the ground and his handle and his lines as close to the ground as defined by the F2C panel of judges until the model aircraft starts again.
john e. holliday
Quote from: Dave Rolley on February 12, 2007, 05:53:02 PM
You are very lucky in that you and Charley work so well together.  JJ at this point in his life has a hard time finding time to practice.  Right now it seems I will have 3 or 4 youngsters for mouse racing in Topeka this year.  Now do you  think putting a speed limit on B-Team race would help?  I know in some parts of the country it has helped bring combat into being again.  DOC Holliday
Dave Rolley
Hi Doc,
I don't know why it worked out the way it did, but Charlie and I are very lucky that we can work together as a father and son team.  We can even share the same workshop.
Yes, practice time has become an issue.  Well, that and the weather.  Charlie had a couple folks leave his store so he is busier that a one-armed wallpaper hanger getting new folks hired and trained.  I've been on the road about 50% so far this year and it is going to increase.  If the timing works out, we may take a weekend and go to Tucson or LA (cheap airfares required) just to practice with our F2C models.
Great to hear the kids are having fun with the mouse racers.  Did you solve your speed button bellcrank for those models?  If not, I use 3-48 or 4-40 blind nuts with the tabs removed and the shank shortened.  If you would like I'll send you pictures of my solution.
I'm not sure the speed is the problem with the B-TRs.  In my case, it is the time to build and debug.  Of course, it might be that I think the model needs to be more complex than is required.  I have a copy of the plans for Don Burke's Nemisis.  It is a neat model and pretty in the air.  The Barton B model looks great too.  I've got a couple of good engines for the event, so that isn't the issue.
I've helped several folks over the last couple of years with their B-TR models at the Nats.  Most of the models I've had in my hands seemed to require special knowledge on the part of the pitman to successfully pit the model. The shutoff and fill mechanisms seem to be the most prone to rather interesting implementations.  The other thing I've noticed is that the B-TR models seem to be very sensitive to the tank position.
Actually, everything I just said also applies to 15 Rat, including my own.
Most of this stuff would get worked out if we raced more often.  I have observed that there is a whole set of mistakes I never make during practice that crops up when I'm in the middle of a race.  Our trips to LA and racing with the folks at Whittier has helped us a bunch in finding those types of mistakes and getting rid of them.
So may be the real solution is more races, regardless of class or event.
later,
Quote from: Bill Little on February 03, 2007, 02:52:07 PM
Ended at $203.50!  OUCH! ;D
More than list price --- Henry should have sold on eBay.
I like Clown as it is.
One good way to keep it "as is" to simply mandate 10/20/70 fuel, for all engines, effectively excluding Diesels.
Considering the F2d change that mandates mufflers and gives an advantage to very light engines, there is  a whole world of Nelson, Cox, Rossi, and SuperTigre F2d engines of pre-1990 vintae, looking for a home.
Les Akre
Hi Scott
The engine Randy is talking about is an O.S. .18 car engine modified for Aero use. In my conversation with Vic, he claims 18.2/7 with 42 laps range.
Not too shabby!
Les
Dave Rolley
Paul,
If you outlaw Diesel engines then the event isn't just "as it is".  You've changed it and likely ticked off those that like the diesels.
BTW, I don't have a diesel for Clown.
don Burke
I thought that leveling the playing field with diesels could be done by reducing the tank size for diesel powered airplanes.  But again last year no one wanted to do that either.  And of course, that's a change.  And by the way, I don't believe in locking the barn AFTER the horse is stolen!
don Burke AMA 843
Menifee, CA
Quote from: Dave Rolley on February 13, 2007, 08:26:01 PM
Paul,
It's sort of a preemptive thing.
There aren't many diesel  Clowns now, so if we disallow 'em before anybody invests, then nobody's out any time or money.   This thing is, F2c allowed either glow or diesel, and the diesels exterminated the glows, and only 4 or 5 teams fly the event.   So my opinion is, if you want diesel 15 racing, fly F2c and get on the team, and leave Clown as sport race event for glows.
Dave Rolley
The last Nats I saw a F2C engine used on a Clown Racer was 2005.  My approach to managing the diesels (banniing integral fin liners) only affects one person that I know of AND I believe that individual has already switched to a F2D engine on his Clown Racer.
I don't know how many folks use a diesel on a Clown Racer, but I have seen several used over the last couple of years.  So banning all diesels will affect several more folks.
Actually, an unshrouded diesel probably isn't the issue everyone thinks it is because you can't control the heat very well.  However, there is a method of heat control that doesn't involve a shroud that the F2CN folks are playing with that will change that statement.
My approach is to apply the minimum change to address the issue.  Banning integral fin liner engines stops the current style of F2C engines being used.  It has the advantage over Don's idea of a smaller tank for diesels of being verifiable by inspection as opposed to being verified by measurement.
I think you are going to find that the .18 car enginies and the F2D engines with a different venturi are going to rise to the top of the heap faster than any of the diesel powered models.
Since the NCLRA controls the event at the national level, you need to make your change request to them.  Likely it is already too late for 2007, but you can always try.
Try http://www.nclra.org
I do wholeheartly agree with Don, closing the door after the horse is gone is a waste of time and will just cause hard feelings.  It is better to be proactive.
Oh, and I already race F2C.  I time and lap count for those that fly Clown Race.
don Burke
Dave,
I have run Nelson diesels in my Clown at various times.  Very promising results.  I do however don't like the stinky fuel and have lately stuck to glows.  "Said I didn't care for them, didn't say I didn't know how to use one!", Quigley Down Under.
And I time and lap count for those who fly F2C, more power to'em!
don Burke AMA 843
Menifee, CA
Dave Rolley
Don,
I remember the line from the movie.  Nice quote.
BTW, those of us that are trying to fly F2C really appreciate the folks that come out and help!
later,
