  • July 19, 2025, 02:39:38 AM
Author Topic: Barrel Nut  (Read 3126 times)
Barrel Nut
« on: August 16, 2020, 01:46:09 PM »
blank
« Last Edit: August 21, 2021, 04:30:07 PM by Motorman »
Offline Tim Stone
Re: Barrel Nut
« Reply #1 on: August 24, 2020, 04:36:33 PM »
What size OD do you guy make your barrel nuts for a 1/4-28 shaft on a powerful engine? I've made them 5/16" on a Go Tech 25 with no failures but I'm upping that to .340". I use 1/2" diameter shank of a grade 8 bolts for the steel.
Motorman 8)
   Thanks for the info but why would you increase prop nut O.D. if you have not had any failures?
   This is not a high stress part. Missed you at the Nats this year, maybe 2021? Showing up talks, BS walks. We need
participants is this is to continue.
« Last Edit: August 25, 2020, 03:34:49 PM by Tim Stone »
