CLICK HERE--><--CLICK HERE
B Team Racer
Started by Paul Smith, January 03, 2022, 10:38:29 AM
Previous topic - Next topic
0 Members and 3 Guests are viewing this topic.
Dave Hull
If we let Les build one, we're going to have to send the Canned Ham racing team to safety school. Both members have participated in blowing up perfectly good B-TRs in the not-distant-enough past....
Most of the teams--at least the pilots--who have campaigned NCLRA B-TR have thought about the horsepower rules. I think Les' suggestion about plain bearing .25's is a pretty good one. You can go look at the last rules that I heard about that the Aussies were running. I think this is pretty much what they have been doing for years.
If the stars were to align and nitro poured out of the sky for free, my Veco B-TR project would get finished and I could probably swap the OS .25FSR for an OS .25FP and we could try it out. Not sure if the bolt patterns and prop spacing is the same, but it might be....
The Divot
"Canned Ham Racing Team"
C.T. Schaefer
After reading Pauls comments the other day I went on ebay and found a number of Enya .29's. Even one NIB with all the venturi's and 2 heads. Also quite a few Fox .29's. The 70's shiny case ones pop up frequently and would make a  very useable powerplant.  I think all this chatter is good!  TS
I noticed several old 29's on Ebay.  The question is: how many would you need to buy to hot a good one?
I my current plan is to send a Fox 35 Stunt over to eastern Europe and have it debored to 29 with an AAC baffled piston.  I am awaiting bids from Ukraine, Slovakia, and Moldavia.  I have six donor engines to convert.  I could cover my cost by selling some of the excess units.
In the short run this will be more effective that fishing on the bay.
Dave Rigotti
Would the NEW FOX 29 being sold on RCG Free Flight and CL classified ads be OK to use?  If so I'd like to buy it and maybe try this event.
Dave Rigotti
AMA 66859
Chesterland, Ohio
C.T. Schaefer
Dave Rigotti
This is all I know....
Dave Rigotti
AMA 66859
Chesterland, Ohio
Charles Barnes
Does anyone have any plans for B Team Racer available?
bob whitney
Charles   email me RAD
rad racer
C.T. Schaefer
Dave, That is a legal motor.  Early 70's fox .29.  Follow standard  Fox procedure with fuel.  I started with 10/25 and had to go to 5/25 for better mileage.
Dave Rigotti
Thanks CT!
Quote from: C.T. Schaefer on January 11, 2022, 05:32:36 AM
Dave Rigotti
AMA 66859
Chesterland, Ohio
M Spencer
A portion of the Aussie Rules .
4.18.1   MODEL SPECIFICATIONS:
(a)   Engine shall be as listed below. It shall be completely cowled with only glow plug, needle valve stem, cut-off lever, (if fitted) fill-vent tubes, or exhaust permitted to protrude through the cowling.An air intake & small access hole for choking is permissible.Allowable engines: Any engine (max. .30 cid) manufactured for commercial sales prior to January 1, 1961. Any "modern" (max. .30 cid) plain bearing engine. Any of the following modern ball race engines are allowed:
OS FX .25
GMS .25
Enya SS.25 BB (diesel or glow)
Thunder Tiger PRO 25 BB
Rothwell R320BR
Irvine .25
ASP .25
Glowplug engines in the above list of modern ball race engines must use a 1/4 " x 32TPI standard thread glow plug. No Nelson plugs, Turbo plugs or button heads are permitted in the modern ball race glowplug engines listed above. No tuned pipes are allowed. No metal engine mounting pans are permitted.
Propellers must be wood or commercially available glass composite (eg APC). All carbon fibre or glass fibre construction not permitted.
4.18.7   SUPPLEMENT TO 2000 "B" T/R RULES
Due to the fact that old racing engines are not readily available, are expensive and those who have or can get them don't always want to use them in competition, a modern engine group has been included with the old engines as allowable power.
Personally , I think the old original engines , while not dime a dozen , arnt hard to find . A lot of the entrant however like modifying any engine beyond recognition , internally .
such as Rossi 15 inside OS 15 case  , etc & so on .
This gives them get up & go . But WHY Super Tigre 21-29s ARNT ELIGABLE is a mystery . They were the hot set up in New Zealand in the early 70s , before schneurle became commonplace .
About 120 mph was as good as it got, with the Super Tigre . Beyond that speed anything but a dedicated T/R nutter will start falling over . ENTRANTS being sparse if they aint a hope . Just a few thoughts ! .
qaz049
Quote from: Air Ministry . on January 11, 2022, 06:42:43 PM
OS FX .25
GMS .25
Rothwell R320BR
Irvine .25
ASP .25
Matt,
you're confusing a number of Australian B Class team racer events. The MAAA rules still allow three separate and distinct events.
(1) Class II TR. This allows any design racer that conforms with the rules. Engines can be any .29 or less. Super Tigre RISE engines were commonly used together with exotic racing engines such as OPS etc. Rossi .21 and other similar Buggy engines were allowed.
(2) Vintage B. Designs up to January 1958 were allowed. Engines were limited to Baffled plain bearing .29's, ETA .29's etc and PB ENYA .29's. Some Vintage diesels were legal.
(3) Classic B. Models could be any that conformed to the 1966 MAAA Class B rules. Engines could be modified PB .25's, Baffled PB .29's or modified TBR .25 glows (no Nelson pluga), OS, TT, Irvine etc.
Most of the other rules were the same.
The Classic B airspeeds were approaching 120 mph with the TBR .25's.
The OS .15's, Norvel .15's etc with Rossi p/l were used in another event, nothing to do with Class B.
Thanks for posting your Australian rules.
As I recall the 1964 AMA Nats was the end of the old B Team Race.  The final winner topped out at 130 MPH airspeed.
The Supertiger G21 series went on sale in the early 1960's, so would just barely qualify as an historic engine.
In our area I never saw two B TR's in the air at once, but we had 24 entries in our first 40-Rat race.  The best speeds were about the same and all you needed to measure on a Rat was the engine and the lines.
My whole interest in the event stemmed from receiving a fixer-upper that I hope to fly.  But I learned that it was a casualty of the rules changing process.
The obvious gap in the current rules is the ability of a few people to get a hold of an old plain bearing baffled piston single bypass engine install a modern AAC pistone y cylindre.
bill bischoff
Paul, it's not that you're a victim of a rule change, you're a victim of not reading!. There are two different events. If you want to fly the event at Brodak or the NATS, change engines and get on with it. If you get more enjoyment from complaining than flying, so be it.
BillLee
Quote from: bill bischoff on January 12, 2022, 09:52:17 AM
Well and properly said, Bill!
Bill Lee
AMA 20018
Dave Hull
Here's one of my "work in progress" B-TRs.  Haven't done anything to it lately, but having a little conversation going here might put some extra "round 'tuits" in play...?
This one started as a Dick Ealy Firecracker. It is a semi-scaler, with a plans date of 1951. I changed a few of the construction methods to things that have worked better for me. I believe I also shortened the fuselage a bit, but I'd have to go verify that. I was pleased with how it was turning out--that's not why the project fell to the wayside. It was just that I had too many other projects--not all modeling--that took priority. But, now may be the time to finish some of these up. Starting with the Veco job.
The picture might be a bit confusing the way the parts are laid out. The long block with internal pocketing is the removable top (even though positioned in the photo like it belongs on the bottom), and the stacked layers of balsa on the top in the picture are actually the bottom of the cowling, which will be permanently attached. I made the cowl out of stacked layers because that opened up a bunch of options in terms of cooling air passages and clearances. Much more like an F2C plane than a vintage B-TR. Since it hasn't flown yet, there is no proof yet on whether that is a good approach. But, it is easy to make very accurately and perhaps a plus if you have trouble getting your hands on a nice-sized block. For the dedicated whittlers out there, you probably will get more fun per dollar using the block....
The Divot
C.T. Schaefer
This has been an active thread which makes me reiterate that there are always a few worthy .29's on ebay.  Right now there is a new Fox and a new Enya. Either one of these can power a fun and competitive TR.  The thought that people would have custom P/L sets made is a bit silly.  There just is no market to support such a course.  As I pointed out in a previous post,  the plane Al and I flew at the Nats  last year has had 4 different engines in it over it's 40 year+ lifespan.   TS
    PS   Dave, Cool looking plane!
