CLICK HERE--><--CLICK HERE
B Team Racer Plans
Started by pat king, July 26, 2022, 07:51:55 PM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
bob whitney
dose anyone have plans for John Barrs FAI or B/TR`s
rad racer
qaz049
Quote from: bob whitney on July 30, 2022, 04:10:39 PM
Do you have his model designs names? John Barr doesn't ring a bell but I might have them under their name.
PerttiMe
#27
Quote from: qaz049 on July 30, 2022, 07:17:10 PM
The only reference to John Barr's designs that I can find quikly is in an article at http://controlline.org.uk/microair/f2c_early/BarrTheo.htm
"John Barr and Dick Norsikian were two of the principals that popularized FAI TR in the US. The plans and 'how to article' on their Minuteman II were published in MAN in 1964. ..."
edit:
Oh, and there's a John Barr 'Firebird Too' rat racer plan and article on https://outerzone.co.uk/plan_details.asp?ID=6746 (MAN 1962)
qaz049
#28
Quote from: Jim Carter on July 30, 2022, 11:43:18 AM
Thanks for the reply and guidance.  I took a look and I did see that they were somewhat reasonable.  Thanks to you, I'll be saving the information regarding parts contacts.  Thank you!!
Jim
Jim,
I've just dug this out of my Vintage B class notes. It's an email I recieved from an old Enya Team Race hand from way back about suitable mods to the .29.
I exchange emails with xxxx xxxxxx a B TR guru quite a few years ago about Enya 29 TR mods.
This is basically what he suggested.
This was the advice from my notes paraphrased slightly:
Quote"I'd recommend going with a well run in Enya 29. It should be nice and free. It might require some fiddling to achieve this. Use a high compression head. The exhaust duration should be about 136/138 degrees. You might have to put a spacer under the cylinder flange to achieve this.The crankcase timing should be:
Open - stock
Close - at 50/55 degrees ATDC.
Use the biggest bore venturi you can which still give you the required laps when using the following:
Prop: APC 8x7
Glowplug: Enya no.5
Fuel: 20% castor, 30% nitro methane, 10% Iso Propyl alcohol, 40% methanol (not Shell A)".
Bob Heywood
The engine rule quoted by Pat King is not exactly correct. The rules require a baffle piston .29. This means that the flat top piston ST G21 engines are not permitted.
http://www.nclra.org/Rules/B-TR/VintageBTeamRaceDayton_rev3.pdf
"Clockwise Forever..."
Bob Heywood
Rambler that won this year's NATS Vintage B Team Race. Veco .29 power. Good solid racer.
Motorman
Just reading the rules. It says the pilots head in the plane must be a dummy head. Had to be in the rules that we don't want real heads in the plane. That's funny to me.
Motorman 8)
bill bischoff
It has to be a dummy head, because nobody smart will put their head in there. n~
Dave Hull
Well, there are dimensional minimums for fuselage height and width. All racers should be smart enough to realize that you want to minimize those dimensions to go fast. Unfortunately with this rule, the NCLRA might be liable for a certain, unnamed guy trying to put his own head in there. Not too far-fetched. I also heard his pitman refers to him as "Pinhead."
The Divot
Dave Hull
John Barr was an early member of the Valley Circle Burners (San Fernando Valley, CA--part of Los Angeles) so it is frustrating that I don't have a better understanding of his designs and accomplishments.
One design of his that I have seen referenced in Pete Soule's writings is the Minuteman 11:
"Two designs from the Valley Circle Burners, the Barr-Norsikian "Minuteman 11" (MAN) and the Brandt-Soule "Framas 9" (to appear in A.M.) are probably the most recently available."  Those with extensive magazine libraries might be able to track these down?
Dave Hull
President, Valley Circle Burners
pat king
All,
Thanks for the great input. The rules for Vintage B Team Race are the Dayton rules on the NCLRA web site. Keeping the engines to engines not larger than .29 with single bypass and baffle top pistons will hopefully keep the class from going into the insanity of .29 size unlimited engine racers.
Anyone that sends me hard copies will have them returned unmolested. Anything I have scanned will have a copy of the scan file sent to the person who sent the hard copy.  I plan to do at least one design with an upright engine and one design with an inverted engine. I may do designs for 3 kits. Once the kit designs are finished, I will send full size .pdf files of the plans for free to anyone who asks.
This is intended to be a fun competition, not to see who can show up with a 120 MPH racer.
Keep your information coming, I have just received 14 pounds of books on Golden Age Air Racers. I am evaluating those airplanes for a possible model. If I have a 3 view I can design a model.
Thanks,  Pat
Pat King
Monee, IL
AMA 168941
