  • June 26, 2025, 06:59:14 PM
Author Topic: Fuel shut off (update attn. Motorman)  (Read 7610 times)
Dwayne
« on: March 19, 2017, 07:26:17 PM »
The Balsa Beavers Club in Toronto are starting a new event, LA 15 sport scale racing using either a Sig Buster or Shoestring, sounds like fun so I'm going to give it a go, I've chosen the Shoestring. There will be 2 prelims off 100 laps with two pit stops and the final will be 200 laps and 4 pit stops. I'm going to need a shutoff and from what I've been told the one from Brodak would be to big and heavy for a 15, anyone have one for a 15 size plane?
« Last Edit: April 02, 2017, 08:16:47 PM by Dwayne Donnelly »
Offline bill bischoff
Re: Fuel shut off
« Reply #1 on: March 19, 2017, 09:37:18 PM »
A piece of music wire and a 1/2 A control horn. Light, simple, bullet proof.  H^^
Re: Fuel shut off
« Reply #2 on: March 20, 2017, 06:03:39 AM »
Right.  Easy enough to make one.  The Brodak unit wasn't all the reliable from what I saw.   Just about anybody can make a contraption with piano wire, wheel collars and a compression spring.
Dwayne
Re: Fuel shut off
« Reply #3 on: March 20, 2017, 07:01:48 AM »
So you make a spring doohickey from piano wire and then connect a wire to the pushrod at the bellcrank? So when you give full up it pulls the doohickey out of the 1/2a horn and pinches the fuel line. Genius.  y1 H^^
Dwayne
Re: Fuel shut off
« Reply #4 on: March 20, 2017, 07:59:29 AM »
No, you pull full down.
Right, down, please where did you hook up the trip wire?
Offline bob whitney
Re: Fuel shut off
« Reply #5 on: March 20, 2017, 08:02:17 AM »
  shut off on the up line is an accident looking for a place to happen, flew a Barten B tr and as hard as I tried I continuously hit the shut off on take off. not fun
rad racer
Offline bob whitney
Re: Fuel shut off
« Reply #6 on: March 20, 2017, 08:06:58 AM »
  if u have your control horn on to of the elav u can attatch shut off wire to the push rod ,or add another small control horn to the elav
rad racer
Re: Fuel shut off
« Reply #7 on: March 20, 2017, 12:31:32 PM »
Here's the one I was looking for.  Simple, reliable.  About an hour's work.
The only thing a little tricky is grinding a square-edge notch in the plunger wire.  You need to cut the plunger about half way through to give the trigger enough bite.
Also, be sure to have the control horn on top.  That way the pushrod will buckle a little and not have the nose move much when you trigger it.
Re: Fuel shut off
« Reply #8 on: March 20, 2017, 03:51:13 PM »
Here's a picture showing the installation. If you build your Shoestring with the bellcrank on the inboard side (per the plans) just install a control horn on the top side of the outboard elevator, and run a cable to the shutoff. Small cotter pins stuck into the fuselage make good cable guides as required.
I recommend you check out my Sportsman Goodyear construction article "Margaret June" on modelaircraft.org. For space reasons, only the introductory paragraphs made it into the print magazine, but the entire construction article is available on line. You might be able to get some ideas.
Bill Bischoff
Dwayne
Re: Fuel shut off
« Reply #9 on: March 20, 2017, 07:03:17 PM »
Thank you so much for all the help, I'll be sure to post pics when i build it, I ordered the kit through my LHS should be here next week.
 y1 H^^ ;D ; ~> #^
Offline Mark Knight
  • Flight is one of mans true adventures
Re: Fuel shut off
« Reply #10 on: March 21, 2017, 07:43:32 PM »
I've used the 1/16th music wire and 1/2 A control horn for 3 of my Sportsman Goodyear racers like Bill is showing in his plans.  They are very effective and easy to make and easy to adjust.
Re: Fuel shut off
« Reply #11 on: March 22, 2017, 12:02:14 PM »
True.
And the reset procedure of a simple shutoff may not be optimum in a race.
« Last Edit: April 05, 2017, 06:58:13 AM by Paul Smith »
Re: Fuel shut off
« Reply #12 on: March 22, 2017, 02:28:06 PM »
They say you can never make something foolproof... Anyway, we've had no problems or incidents locally. I suppose it's all a matter of what you're used to.
« Last Edit: March 24, 2017, 10:45:13 AM by bill bischoff »
Dwayne
Re: Fuel shut off
« Reply #13 on: April 02, 2017, 08:15:48 PM »
Dwayne, Make sure you put a little shape on the bottom of the wing if not almost symmetrical. The Shoe has a big wing and you don't need all that lift. Flat bottom wing Shoestrings fly nose down and they hunt.
Hope that helps,
Thank you for this, the Shoestring wing comes flat and needs to be shaped and the plans show a flat bottom as you state so I sent a e-mail off to our club pres and asked for a clarification, can we shape a symmetrical wing and received a reply that after much debate the rules will be changed to allow what ever shape we want as long as the size of the wing remains stock and we can't change the thickness.
Thank you again  this is a new event for us so there will be much tweaking involved.
 H^^   y1
Offline Balsa Butcher
  • High Desert Flier
Re: Fuel shut off (update attn. Motorman)
« Reply #14 on: April 03, 2017, 08:47:36 AM »
For your next club build consider Bill's Boo-Ray design. Use the details off his Margaret June plans. Not any harder to build than the Sig kits as it uses the pre-shaped wing from the Brodak Flite-Streak Trainer (ordered separately). Mine is close to being finished, fun project.  ;D
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #15 on: April 03, 2017, 10:55:53 AM »
In our part of the country if you start flipping the prop before the go signal means a no start/go signal or you have to shut down and restart.
Offline Al Ferraro
« Reply #16 on: April 04, 2017, 05:30:35 PM »
 I won a lot of races with these.  8)
Al
