  • June 14, 2025, 03:37:55 PM
Author Topic: Blue Sky Models Part 1 (P-38 Rib Set)  (Read 3046 times)
Offline Bill Gruby
« on: December 30, 2006, 09:05:55 AM »
Blue Sky Models              Phone  972-736-3780
Tom Nieburh                   Email   blueskymodels@earthlink.net
7173 FM 1377
Blue Ridge, Tx. 75424
With all that out of the way lets start:
Product----Lazer Cut P-38 Rib Set for Don Hutchinsons P-38 Warbird.
Price------$35.00+$10.00 S&H
Packaging-Bullet Proof---Medium density cardboard box, inside,Rib Set was sandwiched between two layers of  styrofoam with any remaining space taken up by bubble wrap, impossible for anything to move around and get damaged.
Info Sheet--Contains all pertinent info Tom thinks you need to know about this product.
Wood-----4#to6# straight grained balsa, the best I've seen in a long time. Each sheet is almost the same.
             I checked the thickness of each sheet because people have said in the past that sometimes it varies, I
             assure you that these sheets are all the same. All wood is 1/16".
Ribs------The lazer cutting is precise and sharp. The ribs conform EXACTLY to the plans.
So far on a scale from 1 to 10 Tom gets a 10 for his efforts. He has kept me informed via many emails of the progress of this rib set from day 1, letting me know exactly how far along they were. Thank-you Tom.
I start the build up next week, THAT'S PART 2, see you then
Bill Gruby   y1
« Last Edit: December 30, 2006, 02:55:55 PM by Bill Gruby »
Bill Gruby
AMA 94433
MECA 5393-10
Offline Leester
Re: Blue Sky Models Part 1 (P-38 Rib Set)
« Reply #1 on: September 14, 2010, 06:48:07 PM »
It's been awhile since the G Man posted this, but I received my ribs for the P-38 the other day from Tom   New Email    blueskymodels@mypbmail.com
Everything the G Man said.
Leester
ama 830538
Offline Tom Niebuhr
« Reply #2 on: September 29, 2010, 06:01:05 PM »
Thanks for the good words guys.
My contact info changed when I finally got broadband and faster internet access.
New info is:
blueskymodels@mypbmail.com  469-487-1256
AMA 7544
