  • June 15, 2025, 05:27:30 AM
Author Topic: Brodak Shark 402  (Read 4193 times)
Offline Ken Deboy
    • Silk and Dope
Brodak Shark 402
« on: June 05, 2006, 10:50:37 AM »
I just started construction on a Shark 402. It is my second CL kit, the first being a Sig Skyray 35. So far, I'm very impressed with the quality. Airfoil is almost identical to the Skyray, but quality and accuracy is much better. I think I could have just put the parts in a box, shook it real good, and a complete wing would have fallen out. The only thing that was a little confusing is that in the first steps of building the wing, it's actually upside down and the instructions aren't really clear on that. Also, I beefed up the bellcrank mount a little. For about $1.00 more than the Skyray, you get lazer cut parts, adjustable leadouts, and adjustable weight box. Haven't flown it yet but seems like it should fly similar to Skyray - same airfiol but fixed flaps added, almost same wing area, same recommended power range.
Cheers,
There is a fine line between "hobby" and "mental illness"
