  • July 02, 2025, 12:47:19 AM
Author Topic: Brodak .049 MK II  (Read 5628 times)
Offline Bob Zambelli
Brodak .049 MK II
« on: September 25, 2006, 09:57:07 AM »
It's here - the new one from Brodak. More to come very soon but I wanted to get out some preliminary shots.
Re: Brodak .049 MK II
« Reply #1 on: September 25, 2006, 11:13:05 AM »
Here's some more info:
     .400 x .400 bore & stroke
     Weight 1.7 ounces
     12,000 - 18,000 RPM, depending on prop and nitro
     Schnurle ported
     AAC construction
I have been running this engine most of the summer and it looks like a real powerhouse.
The initial fit was quite tight so it's taken a while to run in.
It still needs more time.
The range of props so far is 5-3 up to 6-4.
The picture below shows a comparison of the Brodak crankshaft to one from an OK Cub .049.
As far as I know, they are in stock - delivery and price info from Brodak.
« Reply #2 on: September 27, 2006, 08:21:10 AM »
Is this supposed to be an improvement over the first version.  A couple of flips and it was running.  It also sounded like it was ready for a plane.  DOC Holliday
Offline Ralph Wenzel (d)
« Reply #3 on: September 27, 2006, 09:19:45 AM »
This 'un looks like it's got balls, whereas the original was a plain bearing. True?
Ralph Wenzel
AMA 495785 League City, TX
« Reply #4 on: September 27, 2006, 09:44:57 AM »
Interesting choice of words!!!  ~^
Yes, it's got balls but it's PLAIN BEARING!!!!!   ;)
Initial testing shows that it's a winner.  j1
Offline Tom Perry
« Reply #5 on: September 27, 2006, 11:19:31 AM »
Bob,
I looked on Brodak's Site and didn't see it listed.  The original is  there.
Does the new one come with a muffler?
By the way I got the RHA plans yesterday.  Many thanks.   #^
Tight lines,
Tom Perry
 Norfolk, Virginia
« Reply #6 on: September 27, 2006, 11:25:55 AM »
It will be there soon - it just arrived a few weeks ago.
It is still offered
No
« Reply #7 on: September 27, 2006, 05:25:12 PM »
HI Bob,
Who is making this one for John?  How do you compare it to the Norvel "Start Up" (the milder one) .049?
Bill <><
« Reply #8 on: September 28, 2006, 05:21:18 AM »
Biil - it is made by the same people that make the .25 and .40.  j1 j1
I know nothing of the Norvel so I cannot compare the two.  ???
« Reply #9 on: September 28, 2006, 06:09:08 AM »
Thanks, Bob.  A fellow came to Huntersville last year as a guest of Roy Trantham.  I believe he is the fellow making the engines.  ??? ???
Bill <><
« Reply #10 on: October 02, 2006, 06:32:56 AM »
I visited John Brodak this past weekend and had a chance to put more time on the new .049.
All I can say it that it just keeps getting better.
Easier to start and adjust but this engine needs serious break-in time. It works very well on the Baby Clown but, being new and tight, I'm limiting the fuel to Brodak 10/23.
I will get a hold of some 20% soon and report further when it's broken in.
Offline Larry Renger
« Reply #11 on: October 11, 2006, 09:45:58 AM »
What kind of plug does it use?
Several other people and I have found that adapting the Brodak Mk I to use either the Norvel button or the Nelson Head yields massive increase in rpm and a more reliable run.  Adapting the Mk I to use the Norvel button is really easy.
Remove the gasket, and drill out the plug hole with a size "R" drill.  Put the gasket on top of the cylinder and use the head to clamp the Norvel button in place.  Good for over 1000 rpm in my testing!  Now if only the buttons were currently available....  >:(
On the R/C Universe forum there is a thread about modifying engines to use the "Turbo" style plugs that are popular with the race car guys.  They are available in several brands and many heat ranges.  Supposedly they are as good as the Nelson, but much easier to find.
« Last Edit: October 11, 2006, 06:58:40 PM by Larry Renger »
« Reply #12 on: October 12, 2006, 05:33:12 AM »
Larry - it takes a standard long reach plug.
Since the head is held on with three bolts, which also hold the cylinder to the case, adapting another head would be difficlult.
Hopefully, the attached photo will clarify.
« Reply #13 on: October 14, 2006, 11:08:07 PM »
Good photo, thanks!  Yes, a completely new head would be required, though I think Nelson might actually go to the trouble as he did for the MK 1.  That conversion sure made a marvelous difference in my experience!
I see several places where an astute tuner could pull a few more r's out of the motor.  I shall have to purchase one.   ;D
Any chance of suggesting to the factory that they change the head to use the turbo style plug?  I gather that you are acting as a consultant for them.  It would take minimal tooling change to do, and perhaps they don't realize what a serious benefit would result.
« Reply #14 on: October 16, 2006, 01:54:26 PM »
Larry - thanks for the suggestion.
And, I agree - there will be for sure some tinkering done with this engine for improved performance.
The crank is quite substantial and will permit timing changes.
I would hesitate to tinker with sleeve timing as I don't like to cut through a plating interface.
I need more info on the turbo plug. What is it?
With enough data, I can make a new head in my shop and we can try it side-by side.
I spoke to John a few minutes ago and mentioned it to him - as usual, he's interested in product improvement. I will visit him in two weeks - we'll discuss it more at that time.
« Reply #15 on: October 16, 2006, 06:19:38 PM »
Turbo plugs are standard thread plugs with a beveled bottom so they seal into heads with a matching bevel.  The seal is at the bottom, so the combustion chamber shape is not compormised.  It is supposed to work as well as a full head button type plug.
Enya and a few others make them, primarily for the hotshot car racers.  Tower has several brands!  They should be easy to get, and they are available in various heat ranges.
There was an extensive thread on it in RC Universe.  You should be able to go there and do a search, probably in the small engine forum.  Look at:
http://www.rcuniverse.com/forum/m_4533758/anchors_4533758/mpage_1/key_Turbo%252Cplug%252CCox/anchor/tm.htm#4533758
Offline bill marvel
  • Lafayette Esquadrille, St. Louis
« Reply #16 on: October 17, 2006, 07:16:30 PM »
Bob
After your glowing review, I tried to get a Mark II from Brodak.  I was told they are not quite out yet (about 10 days ago).  I got a chance to get a brand new Mark I (?) at a bargain price and am delighted with it.
What engine mount is that in your posted pictures?  Is it a Dave Brown?  The people on the phone at Brodak couldn't tell me which mount would fit.  Dave Brown has two that are similar sizes.  Help me out, please.
Bill Marvel
Bill Marvel, AMA 793835
Welcome to Stunt Hangar
« Reply #17 on: October 18, 2006, 05:53:28 AM »
Hi, Bill - I think it is a Dave Brown part but I will check.
I just found it at the hobby shop. It's in a clear bag with a yellow tag stapled on.
I now use this type of mount on most of my planes.
Offline bill marvel
« Reply #18 on: October 19, 2006, 02:54:24 PM »
Hey, Bob
Answered by own question.  I was out running errands and stopped by a couple of LHS since they were on my way (That's my story and I am sticking to it!!!).
Dave Brown's Glass Filled Nylon Motor Mount, Model 0506, is an exact fit for the Brodak .049.
Hayes makes one that needs to be slightly camphered to fit.  It is equally well made.  The Hayes motor mount is Model KM-05.  Both were in the same price range of around $2.50.
Hope this is helpful.
bill marvel
« Reply #19 on: October 25, 2006, 05:51:54 PM »
I haven't looked at it in detail, but I think you can drill out the hole from a long plug and leave enough of a land to seal a Nelson plug.  It's tapped 11/32-32, I believe.  The plug taper on the seal is a degree or so more than the angle on a standard drill, you just have to be very careful not to drill too far and get the seal area smooth.
« Reply #20 on: October 27, 2006, 08:22:03 AM »
I just took a closer look at the teardown photo.  I'll bet you can just drill out the head with a size "R" drill, get longer head bolts and clamp down a Norvel plug!  It works great on the MK 1 engine, almost as well as the Nelson head.
Much later:
I was wrong.  I took the head off the Mk. II and it is not a trivial fix.  Too bad.  However, a diesel head could be made for it easily!  Bob Davis where are you?
« Last Edit: April 26, 2007, 10:21:55 PM by Larry Renger »
« Reply #21 on: October 27, 2006, 10:20:04 PM »
Ok, but can it be modified to scream at 19,000 to 23,000 on 35% nitro?? Serious question for 1/2A free flight where the engine runs are very, very short.  ???
I really doubt that it will ever compete with either the Cyclon or Fora; but on the other hand, it doesn't cost $200!
Afterthought - If the B.049 could be made to perform like either of the above-mentioned hotshots, the mods would probably raise the total cost to the same level.
Ralph Wenzel
Offline bill marvel
« Reply #22 on: October 28, 2006, 07:39:44 PM »
(SNIP)
Easier to start and adjust but this engine needs serious break-in time. It works very well on the Baby Clown but, being new and tight, I'm limiting the fuel to Brodak 10/23. (SNIP)
Well, Bob, you are not exaggerating!!!  I have a brand new Model I and it took some real patience and whacked fingers to get it to run the first time.  Every tank full gets better.  It is a fine engine but takes some time to get up to optimum running!  I really like it.
bill marvel
Offline Vincent Corwell
« Reply #23 on: February 08, 2007, 08:01:30 AM »
Hi Bob Z
Is this available now with silencer please?
do you have Brodak part number please ?
Thanks in advance
Vincent
« Reply #24 on: February 08, 2007, 08:14:25 AM »
Hi, Vince - at this point, we are not offering a silencer.
That is, unless something has changed that I'm not aware of.
I find that most people using 1/2 A engines do not bother with a silencer.
And, by the way, if you are running in any of the small Brodak engines, it's best to omit the silencer.
And, only use it if it's really needed.
« Reply #25 on: February 09, 2007, 04:18:23 AM »
Many thanks Bob
I will try one in th enear future, but still
dont see the MK II on Brodaks web site?
Product number
Price
If in stock
What silencer to use, if needed
Vincent
« Last Edit: February 09, 2007, 06:08:37 AM by Vincent Corwell »
Offline Bill Adair
  • AMA 182626
« Reply #26 on: February 24, 2007, 10:57:14 PM »
Vincent,
Sams has them listed on their web site.
Still haven't seen them on the Brodak site.
http://www.sshobbies.com/brodak049mkii.html
