CLICK HERE--><--CLICK HERE
What the CL world needs today. Leadout thimbles (eyelets)
Started by Mark wood, July 30, 2026, 09:58:45 AM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Mark wood
I'm always doing little nifty Dan's. I thought I would share this leadout thimble I have been using. To make a really good one took me a bit longer than I expected when I first sat down. These are the latest generation after lessons learned in service. To get them thin enough for the clips to go over nicely I had to do an iterative modeling process and it took me about an hour. Longer than I expected for such a simple part. Ok, reality is this version was the first of the iterations I tried and maybe it took me only fifteen minutes but who can leave good enough alone.
Recommendations. Use a high temperature filament preferably CF impregnated. PC, Nylon ( PA, PAH, PAH6), ASA, these are ASA CF and I'm flying plain ASA. PETG would be ok but it is just outside expected higher end of environmental sag temperatures. I haven't experienced any service problem with my fielded PETG CF parts, I just prefer more temperature margin. PETG is much easier to work with than any of the "better" materials. Both PETG and ASA work well with proper support materials.
I print these with a 0.4 mm nozzle and the standard Bambu Labs 0.16 mm balanced quality print settings. First layer 0.20 mm and the rest of the layers 0.16 mm. Just to be complete the material is BL ASA CF. I would not use PLA for this part.
**** Update: I did a pull test of the new design and it failed around 20-22 pounds. The original design holds past 30 pounds so, I am taking this version off and I will post the original version.
Like Like x 2 View List
Life is good AMA 1488
"Physics is like sex: sure, it may give some practical results, but that's not why we do it." – Richard P. Feynman
Take off's are optional. Landings are mandatory, it's only a question of quality.
Howard Rush
Cool. Imagine how wee you could make vortex generators.
Mark wood
I've done that too. The trouble isn't making them. It's my motor skills and sight aren't up to the task of installing them.
Howard Rush
Quote from: Mark wood on July 30, 2026, 01:27:25 PMI've done that too. The trouble isn't making them. It's my motor skills and sight aren't up to the task of installing them.
Indeed, having the shakes makes VG installation challenging. One can stir paint merely by holding the can, though.
Mark wood
So, my bad for posting a part that was untested. The change I made was small, about 0.015" in thickness at the inner profile. That was enough the thimble wouldn't stand up to a 30 pound pull test. The original does so here is my original version both pull and flight tested.
