CLICK HERE--><--CLICK HERE
More Tinkering with PETG - Rudder Kicker
Started by Mark wood, August 09, 2026, 12:38:53 PM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Mark wood
I have been sperimenting with a full flying stabilizer model which has potential for an entire thread and discussion. The biggest issue with a full flying stabilizer is that it must be mass balanced in order to not do bad things when in stick free flight conditions. So along the way I explored the mass balancing options and the lightest, although not anything close to light in CL PA terms, way of mass balancing is to use a bob weight. Basically a weight on a stick that is part of the control horn and sticks out a long way so you can reduce the mass balance. Well it works. Actually once the full flying stab is properly mass balanced it works very well.
I have had this long standing how to cure the precession issue. I have flown the hinged propeller, AKA folding propeller and that absolutely cures the precession issues we see. Though the hinged propeller has a very critical problem with blow back which can cause severe line tension loss. The trouble with direct linkage devices is having enough of the right thing at the right time not too much of the wrong thing at the wrong time. K Trossle has an interesting linear cam variation that does this to a degree I think. And certainly this device could be directly connected into the control system but that isn't how the design is derived. The logic behind this was derived from a relationship between G force and pitch rate. At constant velocity the two are directly dependent.
Precession is rate dependent and the best way of approaching this is via a gyroscope or electronic IMU. I think the latter would not be allowed by the rules. Hence the bob weight approach. One trouble we face is that during low to moderate G loops, P factor is the dominating force which is opposite to the gyroscopic pression force. We full size aerobatic pilots know this because for 3-4 G inside loops we have to hold some light pedal pressure for the airplane to track. When we do snap loop kinds of flips and such we have to have a huge boot full of the other rudder. The first version of the cam on this device has a profile that does this however I simplified the design in order to not have too many new things going on during a development test program. The Full Flying Stab (FFS) model still has some test points to try. Even better it is large non flapped model and it really swings it's nose during the square corners making it an ideal candidate for testing both cam profiles. It clearly shows the P-Factor / precession transition.
When you watch some of my tail cam videos you can see the nose makes sort of a figure 8 while flying through the square corners. The nose initially moves out one direction and then goes hard the other way. This is the P-Factor initially winning and as the pitch rate increases it looses. This is also part of the mechanism that drives the snap roll onna string thing. With airfoils that have poor stall characteristics this nose swing causes one wing to stall before the other. With nice behaving airfoils life is fine, with not so good ones, the out going trajectory is subject to chance.
The bob weight beam has two straight wire springs that hold it centered and provide a basic break out force. This will keep the cam centered or close until about 1.5 G - 2 G are encountered. The cam profile extends from 0 to 25 degrees. The first 5 degrees of the profile are constant radius therefore null in terms of deflection. At 5 degrees the G force is passing 3 - 4.5 G and the cam linearly increases deflection up to 25 degrees. The cam is stop limited to 25 degrees rotation. The spring and mass are sized such that this is also roughly 10 G.
The design is set up for a pull - pull drive of the rudder. There are two cam follower arms and there is a positive travel gain of about 1 : 1.25. The output side of the levers will then connect to the rudder with a unified horn. The opposite side of the horn pivot will have stop screws. The result of this arrangement and the bob bob weight after calibration will ( or should)  make the only necessary adjustment the stop screw. Since the cam is null until approximately 4G is occurring there should be any adverse rudder input.
The calibration version of the kicker has the initial design cam which has no null zone. The installation version of the kicker has the null zone version cam. Due to photo size limitations, I'm going to post the calibration separately.
Life is good AMA 1488
"Physics is like sex: sure, it may give some practical results, but that's not why we do it." – Richard P. Feynman
Take off's are optional. Landings are mandatory, it's only a question of quality.
Mark wood
Sperimenting continued. Note. This device has not yet flown but I'm in a rebuild which will include installing this device. See the line above about snap rolls onna string and outgoing trajectories.
The first  photo is the bob weight beam is loaded with 1/2 ounce of lead. In this state the cam is still on the null deflection portion. I connected some 0.015" flying line via a swage to both of the follower levers. This would be the neutral rudder position or what ever level flight / zero G trim you wish. I have a free flight rudder pivot device that could be used to separate the Precession function from rudder trim if necessary. I don't think it is. In extended concepts this idea could be applied laterally as well and you could have it regulate line tension via that same rudder mixing lever. That part already exists and has thousands of flight on free flight models. The take away from this state is that our bob weight could be something less than the 1/2 ounce and still be in the neutral position.
The second photo is the deflection with 5 ounces on the lever. It's not quite enough to be locked up and it somewhere close to 20 degrees deflection. Notice the offset of the output levers. With the cam profile and the lever gain the differential between the output is about 0.2" which should be enough to deflect a rudder depending on it's lever arms. With a baseline weight of 1/2 ounce this position would be the equivalent of 10 G on the airplane. The square loops we make tend to reach into the 12 G -16 G zone which means this should be enough.
So, this thing is a prototype and it began with a concept of using a lever which would have been a bellcrank with a very long output arm. I realized that his would lack some finesse and ability to tune the output. It would be basically an inertia driven Rabe rudder. So, in order to be tunable, I decided to explore the cam and follower approach. The cam followers are flanged roller bearings and arm the primary limiting factor in the design size. There are spring which push on the following levers and there will be some hinge moment that cause friction on the cam surface.
Probably sometime next week I'll fly this and maybe have something to report.
The second photo
