CLICK HERE--><--CLICK HERE
Bambu lab A1
Started by Richard McIntyre, September 14, 2026, 10:28:01 AM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Richard McIntyre
Looking at getting a 3D printer. Never had one before and was looking at the Bambu Lab A1. Any suggestions would be great help. Thanks
Mark wood
I have no experience with the A1. Open frame printers don't work well with high strength materials like ABS, PC, ASA, PAx etc. My advice is, if you intend on making good strong parts for models, go straight to enclosed printers and pass on open frame ones. In the Bambu line up the A1 (open frame) Price point is $299 and the P1S is $399 bare. The combos separate the deal a long way when the AMS are compared. The A1 combo comes with an open AMS for $399 while the P1 comes with the closed 4 spool enclosed AMS. The later AMS can be populated with a bit over a pound of desiccant which will keep your filament dry for several weeks while the open AMS won't keep anything dry. Keeping your filament dry is the single most important part of printing parts. PLA is fairly forgiving but it really isn't very good for parts with outdoors use. PTEG is the bottom of the performance materials and the A1 will print it but it won't work well any of the "good" stuff. The P1 will do a good job of running all of the materials suitable for what we do.
Ultimately this is something you need to do some considering. An open frame will get you started but will quickly run into limitations. Spend another Benjamin will put you into a machine that will continue work for you for many years. The biggest down side to that machine are the plastic transport parts. Those can be replaced. The benefit is the P! can run PC, ASA, ABS PAx and pretty much not be limited for what we do.
I was in this place 10 years ago when I purchase my Ultimaker. The BL printers are way past that machine as half the cost now days. If I went back to that place where you're in now, my choice would be the P1. My first BL machine was the X1C but then the P1 did not exist yet. The X1C ran circles around the Ultimaker in both performance and ease of use.
The A1 combo. I would pass on:
https://us.store.bambulab.com/products/a1?from=home_web_a1_detail&id=771268454723432448
The P1 combo I would get on a budget:
https://us.store.bambulab.com/products/p1s
Note: The P1 combo has an option to get the AMS 2 which has built in heaters which can dry and keep your filaments dry. I don't dry my filaments in the AMS but it is useful to drop the humidity. I would say the additional cost of getting the AMS 2 is worth doing.
My $0.02
Life is good AMA 1488
"Physics is like sex: sure, it may give some practical results, but that's not why we do it." – Richard P. Feynman
Take off's are optional. Landings are mandatory, it's only a question of quality.
Richard McIntyre
Thanks Mark that's what I wanted to know.
Paul Taylor
#3
Get the A1 mini or the A1 you won't regret it. I had an ender three for years and it takes some work to get them printing nicely. You have to stay on top of them. My son says the A1 are like the iPhones you just turn them on and they work.
He was right I got the A1 mini cause I don't really print big stuff and it's handled all my Little needs. I turned my Ender printer off and I haven't turned it back on. I'm actually using the printer bed as a shelf. I'm I'm seriously thinking about getting rid of the ender printer and getting the AMS light so I can print multiple colors on my A1 mini.
My Therapy involves Balsa wood and bad decisions.                               https://www.wpmpa.com
Everyone becomes a memory. The question is: will you be a good one or a bad one?
Kindness echoes. So does cruelty. People remember both.
