CLICK HERE--><--CLICK HERE
I'm Going to hijack my wife's Circut. What do you use for masking?
Started by Donald R Olson, January 05, 2026, 11:59:57 AM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Donald R Olson
I'm going to try using my wife's vinyl cutter to make some stencils/masking.  mw~ My question is what do you use. I'm not sure the best material for this application. Something removable of course. Any advice would be awesome.
Bud Morrison
I have used both mask and vinyl I prefer the vinyl as it gives me cleaner mask edges. If you vinyl is to sticky just stick it on your arm a few times least it works for me there are other methods to make it less sticky.
Paul Taylor
You can use removable vinyl but what I have been cutting for my friend is removable shelving liner.
Post some pictures of your handy work.
I also use it to cut monokote trim.
My Therapy involves Balsa wood and bad decisions.                               https://www.wpmpa.com
Everyone becomes a memory. The question is: will you be a good one or a bad one?
Kindness echoes. So does cruelty. People remember both.
Richard McIntyre
I use 1/4" x 36 yds vinyl that comes in a roll for taping off my lines. Gives very clean edges. To remove the vinyl I use a heat gun from from about a foot away and it peels off real nice with no glue left and does not peel the paint off. . I learned that the hard way the first time I started removing it. I also have a Cricut to make a lot additions to my planes. I use Oracal 651 because its thinner than other brands. Here are a few of my planes that I have used my Cricut to make vinyl decals.
Like Like x 1 View List
Quote from: Donald R Olson on January 05, 2026, 11:59:57 AMI'm going to try using my wife's vinyl cutter to make some stencils/masking.  mw~ My question is what do you use. I'm not sure the best material for this application. Something removable of course. Any advice would be awesome.
So how do you format the design to get the Circut to use it?
Paul Taylor
Quote from: Paul Smith on March 13, 2026, 04:20:04 PMSo how do you format the design to get the Circut to use it?
You can download any image from anywhere in a .jpg or .svg format or you can create your own. Your limited to your imagination.
