CLICK HERE--><--CLICK HERE
Firecat Wheel
Started by Tim Wescott, June 13, 2026, 02:37:52 PM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Tim Wescott
This is Dan McEntee's fault, for asking about printing elastomer.
About the same time I crashed my Firecat, I found out that the wheels that come with Firecats are made of breakable plastic.
You're looking at 19.6 gm on the 3D printed wheel on the left, 9.6 gm on the right.  I estimate that wheel would be about 12 gm if it were whole.
I suspect I could get the weight down, but I have no idea how breakable the result would be when compared with the original.
Like Like x 1 View List
Paul Taylor
Would TPU work?
Maybe make it with hex infill for shock absorption??
My Therapy involves Balsa wood and bad decisions.                               https://www.wpmpa.com
Everyone becomes a memory. The question is: will you be a good one or a bad one?
Kindness echoes. So does cruelty. People remember both.
Jess Walls Gresham
I assume you are trying for accuracy rather than functionality?
How about you print your best effort and use them for display.
Put some light weight, modern, foam wheels on for flying.
Better to fly more often than not.
Jess
Tim Wescott
Quote from: Jess Walls Gresham on July 22, 2026, 02:43:54 PMI assume you are trying for accuracy rather than functionality?
Jess
Hey -- the originals shatter in a crash, my new ones will shatter in a crash.  I think that counts as "functions the same".
