CLICK HERE--><--CLICK HERE
3D Printing Rubber??? Is It Done?
Started by Dan McEntee, June 10, 2026, 10:13:47 AM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
    In answering a question on another group about replacing bad tires on old plastic ready to fly models, I  got the idea that maybe these could be 3D printed?? IS there such a material as a soft and pliable rubber like material? The problem is that the tires on old Cox and some other brands tend to dry out, and crumble to pieces just sitting in the box. If you have a new wheel, cutting the old wire axle doesn't leave you anything to crimp or stake to hold the wheel on. I finally figured out that you can take the tire off another wheel, such as a Perfect brand wheel, and roll that on the old Cox hub and not have to take it off the landing gear assembly. The Perfect wheels are often not an exact fit and need some modifications to make them fit but are good enough for display purposes. I know nothing about the process with these printers, so just putting this out there for opinions. Most tires that are needed are a balloon style, and maybe that presents a challenge? I think if they could be printed, and done in halves to be glued together for the proper shape will suffice. What do you guys think??
  Thanks in advance,
Tim Wescott
The fancy word is "elastomer", and yes, you can print it.  I think you're on track with making them in halves and gluing them.
Now you just need someone who 3d prints.
Tim Wescott
Foam rubber noodles are a thing. If you had the right size could you make a circle of that?
It looks like "sponge cord" is the search term for that.
Matt Neumann
Yes there is some "rubber" or flexible filament that can probably be used to make tires.  It is flexible enough that you probably could just print a donut (tire) and it will stretch around the hub of the wheel without having to print in halves.  I have heard you can make rubber bouncy balls with it.  The biggest issue is coming up with a file so you can print the size you want.  I don't know enough about CAD programs yet to do that.  I do have a 3D printer but only have been printing files I can get off of the internet so far.  I want to learn CAD more but have not had the time.
Matt Neumann
Tim Wescott
I forgot my disclaimer: I've had nice elastomer parts handed to me by mechanical engineers, but I haven't printed elastomer myself.  So if someone with real experience comes along -- listen to them.
I've got an Ender V3 -- it's really nice for what it is, but what it is is a loss leader.  As you try to print softer and softer stuff it gets more and more problematic.  Apparently the really squishy stuff needs a more expensive printer than I have.
You might be able to make a hollow part on my printer that would, overall, be squishy enough to roll on.  Otherwise you probably want to find someone with a nicer printer.
Paul Taylor
The "flexible" filament that I know about is called TPU. I have printed a few things out of TPU. Very flexible and pliable. Not sure how it would stand up to nitro. It does come in some kewl colors. 😁
My Therapy involves Balsa wood and bad decisions.                               https://www.wpmpa.com
Everyone becomes a memory. The question is: will you be a good one or a bad one?
Kindness echoes. So does cruelty. People remember both.
Tim Wescott
Quote from: Paul Taylor on June 12, 2026, 08:56:19 AMThe "flexible" filament that I know about is called TPU. I have printed a few things out of TPU. Very flexible and pliable. Not sure how it would stand up to nitro. It does come in some kewl colors. 😁
What printer did you use?  I'm finding information for the Ender V3 ranging from "can't be done" to "can be done, with care".  Also -- do you know the Shore rating of the filament you've used?  So far I've found 50A and 100A (i.e., pencil eraser to shopping cart wheel); I presume there's everything in between.
Paul Taylor
It was on a Ender 3 Pro.
I haven't printed TPU in a hot minute. It takes some dialing in.
My son printed a lot of TPU on his Ender 3 before he upgraded to a Bamboo Lab.
