  • June 14, 2025, 12:16:19 AM
Author Topic: PERKY laser cut kits  (Read 12556 times)
Offline pat king
    • PDK LLC
« on: June 01, 2019, 03:15:00 PM »
In 1946 Matt Kania designed the PERKY. Today the PERKY is used in postal speed competition. Blackhawk Models used to sell PERKY kits. This laser cut kit is taken from the dimensions of the Blackhawk kit and available plans. The airplane has an 18” wingspan and uses .15 engines. The CAD plans show the airplane and all parts full size. They can be used for scratch building the airplane. There are ribs included for a covered wing or a sheeted wing. The kit contains enough 1/16 Balsa sheet to build the sheeted wing. The horizontal stabilizer and elevator are 1/8” Basswood, the rudder is 1/8 ply. The Bellcrank mount is keyed into the 1/8” Lite Ply bulkhead with a 1/8” ply key. The kit does not contain any control system hardware. The kits sell for $113.85 plus 2 pounds shipping from Zip Code 60449.  Full size .pdf files of the plans are $5.00 delivered to your inbox. I need your Zip code to quote shipping.
« Last Edit: August 29, 2020, 01:44:00 PM by pat king »
Pat King
Monee, IL
AMA 168941
Offline pat king
    • PDK LLC
Re: PERKY laser cut kits
« Reply #1 on: August 29, 2020, 01:41:26 PM »
Bump to top
Pat
Pat King
Monee, IL
AMA 168941
Offline Dave Rigotti
« Reply #2 on: February 19, 2022, 06:18:55 PM »
Pat,
Interested in PDF planset please.  I left you a PM.
Dave Rigotti
AMA 66859
Chesterland, Ohio
