  • June 14, 2025, 04:13:25 AM
Author Topic: Super Ares Profile  (Read 4714 times)
Offline pat king
    • PDK LLC
Super Ares Profile
« on: June 22, 2016, 11:15:15 AM »
This is a profile version of the Bill Werwage Super Ares. The airplane has a 59 11/16” wingspan and 679 square inches of wing area. The kit comes with all the fixturing necessary to build the “I-Beam” wing. The parts are laser cut, all of the wing ribs are laser cut.  The plans are CAD plots with full size templates for all the pre-cut pieces. The built-up version will be available at a later date. All of the wood in the kit is contest balsa. The kit does not contain any control system hardware.
The kits will sell for $260.00 plus shipping. Please indicate whether you want Standard Post or Priority Mail, and if you want insurance. I am not responsible for the package once I deliver it to the Post Office.
Pat King
Monee, IL
AMA 168941
Offline dennis lipsett
Re: Super Ares Profile
« Reply #1 on: June 22, 2016, 03:24:54 PM »
Pat,
As always, just beautiful work.
Dennis
Offline pat king
    • PDK LLC
« Reply #2 on: June 23, 2016, 09:39:54 AM »
Thanks Dennis! I wonder how many Profile I-Beam designs are out there?
Pat
Pat King
Monee, IL
AMA 168941
« Reply #3 on: June 23, 2016, 01:11:57 PM »
perhaps not many, because the ibeam and a profile fuse would localize the stress with great intensitiy on the very very center of the ibeam.
I would be concerned without some very substantial reinforcement,,
but, then thats just my observation, perhaps your design addressed this shortcoming?
Offline pat king
    • PDK LLC
« Reply #4 on: June 24, 2016, 12:12:04 AM »
Where the fuselage and spar are in contact the fuselage/rootrib assembly is 2 1/4" wide. The 3/8 balsa spar web is 1 3/8" tall in the center, the flanges top and bottom are 1/8 X 1/2 balsa. the spar doublers front and backside of the spar are 1/16 ply between the flanges and are over 22 inches long. There are 1/16 ply spar tripplers front and backside of the spar assembly that are 1 5/8 tall and 5 7/8 long. The spar assembly has 1/8 ply tripplers top and bottom that are 3" long.
I doubt that aerodynamic forces can break a properly assembled spar.
I admit that I had to abandon my traditional choice S section I beam for this application, but the wing is not thick enough, and I don't think we have engines that could lift even the little S6 10# section. LL~  In my professional career we considered anything less than 1/4" plate as sheet metal. We stocked plate up to 8", and I have designed and built products that use 12" plate.
Pat King
Monee, IL
AMA 168941
Offline Dane Martin
  • heli pilot BHOR
« Reply #5 on: June 24, 2016, 10:41:56 PM »
Pat,
I'm kinda diggin this the more I look at it.
At this size, what kind of engine would be used?
I have a k&b 60 in need of a home
Offline pat king
    • PDK LLC
« Reply #6 on: June 25, 2016, 05:51:19 AM »
Dane,
The Super Ares is a .60 size airplane. Any good .60 should fly it well. I sure wouldn't try it with an old engine that couldn't pull a fat girl off of a toilet. Your K&B should be a good choice.
Pat
Pat King
Monee, IL
AMA 168941
