  • July 31, 2025, 02:15:25 AM
Author Topic: Ringmaster X-Wing RC  (Read 1952 times)
Offline pat king
    • PDK LLC
« on: December 15, 2017, 01:27:16 PM »
This laser cut kit builds an Electric RC Ringmaster X-Wing. The airplane has a 49 5/8” wingspan and 936 square inches of wing area. It will accommodate an electric motor up to 50mm in diameter. It will accommodate a 5 cell battery. The top wing is bolted to the fuselage, it incorporates much of the top of the fuselage. With the top wing removed the top of the airplane is open from 1” behind the front frame to 22 7/8” behind the front frame. The bottom wing is bolted to the fuselage it incorporates a hatch that forms part of the fuselage bottom. The wings are bolted on using ¼-20 Nylon bolts. Both wings have ailerons. The “Vee-Tail” adds to the look of the airplane. The CAD plans show all parts full size. The kit does not include the main gear. The kits will sell for $275.00 plus shipping for a 36 X 6 X 6 box weighing 8 pounds from Zip 60449.
Full size .pdf files of the plans sell for $5.00 delivered to your inbox.
A C/L version will be available at a later date. The C/L airplane will not have flaps. The wings will bolt on.
Pat King
Monee, IL
AMA 168941
