  • July 31, 2025, 02:12:01 AM
Author Topic: RINGMASTER Jr. TRAINER  (Read 19264 times)
Offline pat king
    • PDK LLC
« on: April 08, 2015, 04:42:43 PM »
A step up from sheet wing 1/2A trainers. The simplicity and ease of repair of a sheet wing in an airplane for .09 to .15 engines. A .19 is too much engine for this airplane. The airplane has a 33” wingspan and 225 square inches of wing area. This size airplane is easier to fly than a 1/2A airplane, but not large enough to be intimidating for the youngsters. Put this one on 52’ lines and get the rotational speed down to a comfortable level. The laser cut kits will sell for $53.00 delivered in the continental US.
Pat King
Monee, IL
AMA 168941
Offline pat king
    • PDK LLC
Re: RINGMASTER Jr. TRAINER
« Reply #1 on: March 24, 2017, 08:25:53 AM »
A picture of the finished airplane. This one will be a club trainer.
Pat King
Monee, IL
AMA 168941
Offline James Holford
« Reply #2 on: April 05, 2017, 05:15:23 AM »
Pat what is the stunt capability with this plane and the bigger Trainer II? Thinking on getting either this Jr. or the bigger one to help learn that pattern. Looks like these can take a beating compared to me constantly busting up a very heavy hand me down. Thanks
Jamie Holford
Baton Rouge Bi-Liners
Lafayette, La
AMA #1126767
Re:
« Reply #3 on: April 05, 2017, 10:45:02 AM »
 Beginner pattern I should say. Simple loops and 8's and invertes
Jamie Holford
Lafayette, La
AMA #1126767
Offline pat king
    • PDK LLC
« Reply #4 on: April 05, 2017, 01:05:50 PM »
Jamie,
The Jr. trainer is capable of inside, outside maneuvers, inverted, eights, wingovers. It will not be perform square or hourglass stuff unless the pilot is an expert. The Trainer II should not be put in negative G (outside) maneuvers, the rubber bands would be the only thing taking all the load from the fuselage, tank, and engine.
Pat
Pat King
Monee, IL
AMA 168941
Re:
« Reply #5 on: April 05, 2017, 03:06:07 PM »
Awesome.  With the trainer II I would glue the wing in place just so I don't have to deal with rubber bands. But the Jr. May be the ticket.
Jamie Holford
Lafayette, La
AMA #1126767
Offline pat king
    • PDK LLC
« Reply #6 on: April 06, 2017, 06:42:11 AM »
Jamie,
I will be doing a Ringmaster Trainer III with the wing and tailfeathers fixed (glued) to the fuselage. #^ #^
Pat
Pat King
Monee, IL
AMA 168941
Re: Re: RINGMASTER Jr. TRAINER
« Reply #7 on: April 06, 2017, 10:19:34 AM »
Jamie,
Pat
Ohhh I think I'll wait for that one then :):)
Jamie Holford
Lafayette, La
AMA #1126767
Offline pat king
    • PDK LLC
« Reply #8 on: April 06, 2017, 11:01:19 AM »
Check out the trainer III #^ #^ #^
Pat
Pat King
Monee, IL
AMA 168941
Offline Dalton Hammett
« Reply #9 on: April 22, 2017, 12:39:44 PM »
Hi Pat
      I think you may have hit the perfect trainer for the kids,   one of these matched to one of the old Gilbert .11s should be fun to fly.   Do you have one of these available ???
Dalton
Dalton Hammett
Albion, Pa.
Bean Hill Flyers
AMA  29918
Re:
« Reply #10 on: April 23, 2017, 06:44:20 AM »
Dalton I still that Gilbert .11 you have me years back. You just brought an interesting idea to my head. Post results if you go this route
Jamie Holford
Lafayette, La
AMA #1126767
Offline pat king
    • PDK LLC
« Reply #11 on: April 23, 2017, 05:21:33 PM »
Dalton,
I do not have a Ringmaster Jr. Trainer in stock. It would take about 3 weeks to get one for you.
Thanks,  Pat
Pat King
Monee, IL
AMA 168941
« Reply #12 on: April 23, 2017, 07:19:57 PM »
Hi Pat
Not a problem,   I will send you a check this week for one.
DH
Dalton Hammett
Albion, Pa.
Bean Hill Flyers
AMA  29918
« Reply #13 on: April 24, 2017, 02:25:12 PM »
Pat
Pmt sent - no rush......
Dalton Hammett
Albion, Pa.
Bean Hill Flyers
AMA  29918
Offline pat king
    • PDK LLC
« Reply #14 on: April 24, 2017, 04:52:03 PM »
Dalton,
The laser cuts are on order. I have to check my stock for the flat wood.
Thanks,  Pat
Pat King
Monee, IL
AMA 168941
