  • June 14, 2025, 02:11:26 AM
Author Topic: PT 19A PROFILE SCALE  (Read 9397 times)
Offline pat king
    • PDK LLC
« on: June 19, 2020, 09:33:14 PM »
This laser cut kit builds a Profile Scale 1 ½” = 1’-0” (1/8 Scale) model of the Fairchild PT 19A. The airplane has a 54” wingspan and 438 square inches of wing area. The wing has the stock NACA 2416 root rib profile and the stock NACA 4409 tip rib profile. The wing has the scale 2 angle dihedral and is fully sheeted. The wing is set a one degree positive incidence; the horizontal tail is set at 45 minutes positive incidence. The airplane is recommended for .45 size engines even though it only has 438 square inches of wing area. The fully sheeted wing increases wing loading and the size of the airplane says it doesn’t want a worn out old .35 or .40. The CAD plans ARE 3 SHEETS 36” x 62” that show all parts full size. The kit does not include the control system hardware, but does include the 3” Glass Filled Nylon Bellcrank. The kit includes the file for a specification sheet for the airplane and the file for an 8 ½ X 11 multi-view drawing of the airplane. The kits sell for $216.00 plus Priority Mail Shipping of 4 pounds from Zip 60449
Pat King
Monee, IL
AMA 168941
