  • July 10, 2025, 09:16:45 PM
Author Topic: PT 17 Kit Survey  (Read 8731 times)
Offline pat king
    • PDK LLC
PT 17 Kit Survey
« on: February 05, 2011, 08:43:21 AM »
Which would you be most likely to buy?
32 1/4" wingspan, 301 square inch, built-up wing, profile fuselage PT 17 for .19 to .35
22 9/16" wingspan, 148 square inch, built-up wing, profile fuselage PT 17 for 1/2A
22 9/16" wingspan, 148 square inch, sheet wing, profile fuselage PT 17 for 1/2A
I want to do a profile PT 17, but want to know which one to spend my time on.  y1
Thanks,  Pat
Pat King
Monee, IL
AMA 168941
  • Gravitywell
Re: PT 17 Kit Survey
« Reply #1 on: February 05, 2011, 12:24:51 PM »
The 32 1/4" would be a real dream build for me, but the small sheet wing would be just way to much fun....and the grandkid could fly it too!   So I guess the sheet wing for me....but the big one would be sooooo cool!  Hope this helps.H^^
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
Offline pat king
    • PDK LLC
« Reply #2 on: February 05, 2011, 12:58:49 PM »
Thanks Glenn,
All input helps. We will see which one I do first. Will probably do the big one and one of the 1/2A size airplanes.
Pat
Pat King
Monee, IL
AMA 168941
Offline pat king
    • PDK LLC
« Reply #3 on: February 12, 2011, 08:13:43 AM »
Thanks,  Pat
The design drawing is coming along for the 32 1/4" airplane. Once the design file is done I will do the formal plans drawing and the parts drawing for the laser cutting. The slanted N-Struts make the construction interesting. I think I have come up with a decent method of doing that. I will keep this updated. I will probably build one of these, the PT 17 is one of my favorite airplanes. #^
Pat
Pat King
Monee, IL
AMA 168941
Offline dennis lipsett
« Reply #4 on: February 12, 2011, 08:33:41 PM »
Do the bigger one first.
Dennis
Offline pat king
    • PDK LLC
« Reply #5 on: February 12, 2011, 10:05:19 PM »
Dennis
I be workin on it.  y1 The laser cuts are ordered for the Flying Fool, I have to order some wood. I'll do that Monday or Tuesday.
Pat
Pat King
Monee, IL
AMA 168941
Offline james p wood
« Reply #6 on: August 21, 2011, 05:08:03 PM »
I would be most interested in a PT-17 with built up wing in 1/2A
AMA 930806
Offline pat king
    • PDK LLC
« Reply #7 on: August 21, 2011, 05:13:26 PM »
It will be a bit before the PT 17 1/2A airplane with the built-up wings is available. It will be a 1/16 scale airplane for beam mount engines. It will have a 24 3/16" wingspan and 169.4 square inches of wing area.
Thanks,  Pat
Pat King
Monee, IL
AMA 168941
