  • July 10, 2025, 09:17:25 PM
Author Topic: PEGASUS 1/2A Stunter  (Read 3160 times)
Offline pat king
    • PDK LLC
« on: February 12, 2013, 02:29:39 PM »
The PEGASUS is designed for .049 to .061 beam mount engines. The airplane has a full fuselage, wing mounted gear, adjustable leadouts, a weight box, and flaps. It is designed for a balloon tank.  The bellcrank is suspended, the kit has parts to build the 1/16 flap horn using music wire and a 1/32 ply horn arm. PEGASUS has a 34” wingspan and 235 square inches of wing area. If you are looking for a new 1/2A stunter this is an option. The kits will sell for $75.00 delivered in the Continental US.
Pat
Pat King
Monee, IL
AMA 168941
Offline Duke.Johnson
Re: PEGASUS 1/2A Stunter
« Reply #1 on: February 12, 2013, 03:00:28 PM »
would this plane work well witha thunder tiger .070?  I just pick up one at a swap meet.
Offline pat king
    • PDK LLC
« Reply #2 on: February 12, 2013, 04:05:20 PM »
The airplane is .70" between the mounts. They could be cut away to clear a crankcase of .80" (13/16"). Unless the Thunder Tiger is wider than that it should fit fine. The design was done around an AP Wasp (Norvel clone) and a COX TD 049.
Pat
Pat King
Monee, IL
AMA 168941
Offline pat king
    • PDK LLC
« Reply #3 on: February 28, 2013, 04:39:52 PM »
Here is the front of the airplane showing the Lee 1" spinner.
Pat
Pat King
Monee, IL
AMA 168941
