  • June 13, 2025, 07:13:45 AM
Author Topic: STEARMAN 55  (Read 2549 times)
Offline pat king
    • PDK LLC
STEARMAN 55
« on: June 22, 2018, 01:04:10 PM »
This laser cut kit is to build a Profile Scale Boeing-Stearman Model 76 for national level competition. The Stearman is a large airplane. This airplane has a 55 inch wingspan on the top wing and 860 square inches of wing area. It is for .60 to .74 engines. This airplane has the correct NACA2213 rib profile, ½ degree dihedral on the top wing and 1 ½ degree dihedral on the bottom wing. The top wing has a 4 degree incidence; the bottom wing and horizontal stabilizer have a 3 degree incidence. The CAD plans show all parts full size. The kit comes with a .pdf of 3 views and specs of the airplane. The kit does not contain any control system hardware. Shipping weight is 6 pounds from zip 60449. I sell a set of full size .pdf files of the plans for $5.00 per set. The kits sell for $235.00 plus shipping.
Pat King
Monee, IL
AMA 168941
