  • June 13, 2025, 07:09:30 AM
Author Topic: Aldrich PEACEMAKER  (Read 2112 times)
Offline pat king
    • PDK LLC
Aldrich PEACEMAKER
« on: May 19, 2018, 08:37:39 PM »
George Aldrich designed the PEACEMAKER for Aeromodeler magazine. It was published in the February 1958 issue. It is sort of a small “Flite Streak” with the points rounded off. The airplane is a Stunt/Combat airplane for .15 to .21 engines. The PEACEMAKER has a 36 ˝” wingspan and 296 square inches of wing area. The laser cut kit has CAD plans that show all parts full size. The kit comes with bellcrank, control horn, pushrod wire, and the pivot pin for the suspended bellcrank. The kits will sell for $71.00 plus shipping. The kit contains a copy of the Aeromodeler article. Full size .pdf files of the plans are available for $5.00 per set.
Pat King
Monee, IL
AMA 168941
