  • June 14, 2025, 04:15:58 AM
Author Topic: Typhoon Electric Profile Stunter  (Read 1865 times)
Offline pat king
    • PDK LLC
« on: March 24, 2016, 02:29:12 PM »
This airplane is based on the Typhoon Stunter flown by Chris Rud at the 2014 NATS.  It has an improved wing size as recommended by Chris Rud. The wing has 2” less span and 3/4” more chord. The airplane has a 61 1/2” span and 717 square inches of wing area. The airplane is designed for a 42 mm outrunner motor. The battery is inset 5/16” into the outboard side of the fuselage. There is a cheek cowl on the inboard side of the fuselage to cover the electronics. The laser cut kit comes with full size CAD plans that have full size templates of all parts. The kit does not include any control system hardware. If you would like a less expensive profile version of a top NATS airplane then this one is for you.  The first kits will sell for $245.00 plus shipping.
Thanks,  Pat
The price went up. I underestimated the cost of these kits.
« Last Edit: May 03, 2016, 09:13:38 PM by pat king »
Pat King
Monee, IL
AMA 168941
