  • June 14, 2025, 03:59:57 AM
Author Topic: Profile Scale F7F-1 Tigercat  (Read 6787 times)
Offline pat king
    • PDK LLC
« on: June 02, 2014, 03:11:44 PM »
This laser cut kit is for a .15 size F7F-1 Tigercat. The airplane is Profile Scale. It has a 56” wingspan and 553 square inches of wing area. The CAD plans have all parts full size. If you want a great looking twin warbird that isn’t toy sized you will like this one. The first kits will sell for $175.00 postpaid in the lower 48.
Thanks,  Pat
Pat King
Monee, IL
AMA 168941
Offline Jim Dincau
Re: Profile Scale F7F-1 Tigercat
« Reply #1 on: October 20, 2015, 02:09:13 PM »
Pat,
     What is included in this kit?
Jim
Unless it's crazy, ambitious and delusional, it's not worth our time.
Offline pat king
    • PDK LLC
« Reply #2 on: October 20, 2015, 03:29:34 PM »
Jim,
Send your email address to: patdk@aol.com and I'll email you 8 1/2 X 11 .pdf files of the plans and the packing list for the kit. The kit does not contain any control system hardware. It contains music wire for the gear, you have to bend it.
Thanks,  Pat
Pat King
Monee, IL
AMA 168941
« Reply #3 on: October 31, 2015, 08:58:20 PM »
 The Tigercat looks GREAT Pat! y1
 Any chance of a duplicate size/version with a stunt airfoil? Just add two FP/LA.25's... S?P ;D
Offline pat king
    • PDK LLC
« Reply #4 on: October 31, 2015, 10:05:00 PM »
Wayne,
I can do a version with a symmetrical airfoil. A pair of .25 engines is a lot for an airplane that only has 553 square inches. A pair of .19 engines would be more than enough for this airplane for stunting. The Scale bird should do well for loops, wingovers, and lazy eights with a pair of .15 engines.
Pat King
Monee, IL
AMA 168941
Offline pat king
    • PDK LLC
« Reply #5 on: October 31, 2015, 10:07:40 PM »
 :'( I badly underpriced this airplane. All future kits will sell for $214.00 postpaid in the CONUS. :'(
Sorry for the mistake,
Pat
Pat King
Monee, IL
AMA 168941
« Reply #6 on: November 01, 2015, 01:26:13 AM »
Pat
 I don't know if it's just me or what, but it seems like shipping rates have really gone up in the past year. :(
« Reply #7 on: November 01, 2015, 01:37:17 AM »
Wayne,
 The main reason I suggested the .25's is that they are fairly easy to find, more so than a pair of good .19's it seems. Also, the weight difference between the .19's and the .25's would be practically nothing.
 Square inches aside, there is still 56" of frontal area (=drag) in the wing. Just my opinion, but in a stunt version I'd go with .25's on this design, it's never a bad thing to have some reserve power rather than squeezing the turnip. ;D
Offline pat king
    • PDK LLC
« Reply #8 on: November 02, 2015, 08:40:38 AM »
Wayne,
If I design a kit with a symmetrical airfoil and no dihedral the tanks would have to go on the inside of the nacelles.
Pat
Pat King
Monee, IL
AMA 168941
« Reply #9 on: November 02, 2015, 06:28:05 PM »
Wayne,
Pat
 Pat,
 Not sure what you mean by that. Are you saying the tanks would each be between the nacelles and the fuse?
Offline pat king
    • PDK LLC
« Reply #10 on: November 02, 2015, 09:36:43 PM »
Wayne,
With the wing lower and somewhat thicker at the Nacelles there would not be enough room for a normal tank behind the engines. A 2 oz. Perfect tank would fit. Larger tanks would be mounted to the inside of the circle, opposite the engines.
Pat
Pat King
Monee, IL
AMA 168941
« Reply #11 on: November 03, 2015, 06:49:06 PM »
 So you if you lowered the wing would you also put the controls inside it? You wouldn't have to you know... ;D
Offline pat king
    • PDK LLC
« Reply #12 on: November 03, 2015, 10:45:32 PM »
I wouldn't lower the wing in the fuselage, but taking the dihedral out effectively lowers the wing in the nacelles. I would put the controls inside a straight wing.
Pat
Pat King
Monee, IL
AMA 168941
« Reply #13 on: November 04, 2015, 06:15:01 PM »
Pat
 Ahh, got it. ;D
