  • June 13, 2025, 08:48:46 AM
Author Topic: RINGMASTER TRAINER BIPE  (Read 2855 times)
Offline pat king
    • PDK LLC
« on: August 03, 2019, 06:13:25 PM »
This is a 33” wingspan 430 square inch biplane primary trainer. The airplane has ¼” thick balsa sheet wings. The wings and tailfeathers are glued into and onto the airplane. The “N-struts” set the two wings at zero incidence.  The airplane is for .25 to .40 engines. The 33” span airplane is easier to store and transport than a 42” span airplane. This larger airplane is much easier to fly than a 1/2A size airplane, plus a biplane is cooler than a monoplane. The kit has CAD plans with full size templates of all the parts. The laser cut kits sell for $125.00 plus 6# shipping from 60449. A set of full size .pdf files of the plans are available for $5.00 .
Pat King
Monee, IL
AMA 168941
