  • June 14, 2025, 04:11:41 AM
Author Topic: P-47 Profile Stunter  (Read 9782 times)
Offline pat king
    • PDK LLC
« on: March 20, 2016, 10:25:05 AM »
This airplane is based on the P-47 Stunter designed by Bill Werwage.  It has an improved wing size as recommended by Chris Rud. The wing has 2” less span and 3/4” more chord. The airplane has a 61 1/8” span and 719 square inches of wing area. The airplane is designed for .60 to .67 size engines. The laser cut kit comes with full size CAD plans that have full size templates of all parts. The kit does not include any control system hardware. If you would like a less expensive profile version of a World Championship airplane then this one is for you. The first kits will sell for $245.00 plus shipping for a 6 X 6 X 36 box weighing 5 pounds from zip 60449
Pat
The price went up. I underestimated the cost of these kits.
« Last Edit: September 21, 2017, 01:05:29 PM by pat king »
Pat King
Monee, IL
AMA 168941
Re: P-47 Profile Stunter
« Reply #1 on: March 20, 2016, 08:13:47 PM »
 Another great offering Pat, if I could only have the time to build everything I'd like to.
 One thing I notice every time but can't figure out, why is it that no one ever gets the wingtip outline anywhere near right with the P-47 designs? I know we're not building scale here but... ???
« Last Edit: March 20, 2016, 08:47:07 PM by wwwarbird »
Offline pat king
    • PDK LLC
« Reply #2 on: March 20, 2016, 10:47:29 PM »
Wayne,
The tips match the Werwage P-47. I don't know why they are not the same shape as the full scale airplane. The tips on my 1/2A P-47 are scale.
Pat
Pat King
Monee, IL
AMA 168941
Offline Allan Perret
  • Proverbs
« Reply #3 on: March 21, 2016, 07:17:06 AM »
Do you sell just the plans ?
Allan Perret
AMA 302406
Slidell, Louisiana
Offline pat king
    • PDK LLC
« Reply #4 on: March 21, 2016, 11:37:48 AM »
Allan,
Full size .pdf files of any of my airplane plans are $5.00 delivered to your inbox.
Pat
Pat King
Monee, IL
AMA 168941
« Reply #5 on: March 21, 2016, 08:57:41 PM »
Wayne,
Pat
 Yup, I'd noticed that too, just thinkin' out loud. ;D
Offline pat king
    • PDK LLC
« Reply #6 on: March 22, 2016, 08:07:54 AM »
Admit it. You just like to rattle my cage to get my reaction. ;D
Pat
Pat King
Monee, IL
AMA 168941
  • Proverbs
« Reply #7 on: March 22, 2016, 04:32:19 PM »
This airplane is based on the P-47 Stunter designed by Bill Werwage.  It has an improved wing size as recommended by Chris Rud. The wing has 2” less span and 3/4” more chord. The airplane has a 61 1/8” span and 719 square inches of wing area. The airplane is designed for .60 to .67 size engines. The laser cut kit comes with full size CAD plans that have full size templates of all parts. The kit does not include any control system hardware. If you would like a less expensive profile version of a World Championship airplane then this one is for you. The first kits will sell for $190.00 plus shipping.
Pat
Does it have the same tail volume as Billy's design ?
Allan Perret
AMA 302406
Slidell, Louisiana
Offline pat king
    • PDK LLC
« Reply #8 on: March 22, 2016, 09:37:29 PM »
The shapes of the empennage are lifted out of the files for the P-47 that Chris Rud is selling as Werwage and Son. Other than the wing span and chord the all the shapes are from the files for the built-up stunter. If the chord on the ribs is scaled to match the built-up stunter the rib profiles are no more .015" off of the rib shapes of the built-up stunter.
Pat
Pat King
Monee, IL
AMA 168941
Offline pat king
    • PDK LLC
« Reply #9 on: March 23, 2016, 11:16:38 AM »
Allan,
If you are asking about the Tail Volume Coefficient, as calculated by the following formula:
Tail Volume  =  (Tail Area/Wing Area) X ( Tail Arm/Wing Avg. Chord)  where:
 Tail Area = area of the horizontal stabilizer
Wing Area = area of the wing
 [both areas include that encased by/covered by the fuselage]
 Tail Arm = distance from LE of wing to LE of stab [for untapered surfaces; for tapered, use LEs at average chord]
 Wing Avg. Chord = area  / wing span
 Billy's airplane TVo = 0.24131
The profile airplane TVo = 0.22465
Pat
Pat King
Monee, IL
AMA 168941
« Reply #10 on: March 23, 2016, 11:32:37 AM »
Pat are you sure about that, typicall stunt TVC numbers are closer to .4-.5
Offline pat king
    • PDK LLC
« Reply #11 on: March 23, 2016, 12:49:08 PM »
Mark,
The formula uses the area of the horizontal stabilizer. If the same calculation is run using the area of the entire horizontal tail the numbers would be larger. The number for the profile airplane is .39247 if the calculation uses all of the horizontal tail.
Pat
Pat King
Monee, IL
AMA 168941
« Reply #12 on: March 23, 2016, 02:54:13 PM »
Pat,
respectfully, The formula as I was taught is defined differently
the Horizontal stab area by definition INCLUDES the elevators
the second portion is
(the distance from the CG  to the center of the stab[what you call the tail arm]) divided by the MAC
« Reply #13 on: March 23, 2016, 06:00:52 PM »
 I just stick to the eyeball and tape measure formulas. ;D
Offline Walter Hicks
« Reply #14 on: March 23, 2016, 07:58:53 PM »
Mark, hold on you will see this plane in action it will have one of my K 77 engines in it
« Last Edit: March 23, 2016, 10:14:21 PM by Walter Hicks »
Offline pat king
    • PDK LLC
« Reply #15 on: March 23, 2016, 08:46:24 PM »
Pat,
Mark,
I was not taught any formula for tail volume coefficient because I am a Mechanical Engineer, not an Aeronautical Engineer. When I searched for a method to calculate Tail Volume Coefficient I found several formulae. I will re calculate when I get a chance. Right now I have to do some reading, investigation, then write a proposal for a potential client. The design consulting takes precedence over airplane or boat design.
Thanks,  Pat
Pat King
Monee, IL
AMA 168941
« Reply #16 on: March 23, 2016, 10:03:45 PM »
Mark,
Thanks,  Pat
Hey Pat, hope you understand I am just trying to be helpfull, a TVC of .220 with flaps is pretty meager so it made me wonder, especially when you calculated Billy's at .240,, mOst modern designs are above .450 . I was shown this by Pat Johnston and others. there is some relevant discussion on here if you do a search for "TVC"
Walter, I look forward to seeing it with a High zoot engine in it,,
Offline pat king
    • PDK LLC
« Reply #17 on: March 24, 2016, 08:32:36 AM »
Mark,
No offense taken. As I am not an Aero E I don't know about such things. I will do the constructions and calcs before the weekend is over.
Thanks,  Pat
Pat King
Monee, IL
AMA 168941
Offline pat king
    • PDK LLC
« Reply #18 on: September 21, 2017, 01:07:04 PM »
Bumping this up to help answer a question.
Pat King
Monee, IL
AMA 168941
